Question about Acer Aspire 5050-3242 Notebook
I turn my Acer 5050 on . Screen stays black. There may be a quick orange light then it will go black. You can see very faintly the images in the dark of the screen. Can anyone help me?
  • Aaron Fox
    Aaron Fox May 11, 2010
    Try connecting your VGA output to a regular monitor, let us know what happens.
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
Laptop black out
When the following situations, you need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More:http://www.lcdinverter.info/acer-travelmate-8001-lcd-inverter-p-2046.html
Aug 08, 2013 | Acer Computers & Internet
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
Black screen
If its LCD get the room very very dark and turn on--with a flashlight near the screen look closely at the screen to see if you see a very faint image of the picture or not---Most LCD flatscreen's (not Plasma) use what is called a back light to light the screen--light source.
If a faint picture can be seen that way the light is not on.
Dec 17, 2012 | Sceptre Televison & Video
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Dec 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
I had some water on my screen and the screen is
dear sir my acer desktop pc sound not working sound properties open full option hide
rajan dubai
Mar 20, 2010 | Acer Aspire 5050-5410 Notebook
Power comes on but the screen stay`s black dose it have a screen lock or stand by
Black screens can be caused by many things the first bit of video runs through the ram, so try changing the ram or swaping it. the next thing that causes a black screen is the LCD Inverter or the back light bulb to test this is take a flash light and shine it on the screen at an angle and see of you can make any faint images out. Next dis-assemble the laptop and see if the processor is heating up or staying cool.
Hope this helps!
May 02, 2009 | Acer Aspire 1640Z Notebook
Black screen / HD light steady and the fan keeps running
Ok, check your RAM, reseat or clean it with soft eraser, only its edge connector both side. Do this when unit is off and no other power source is connected to it even its battery.
Hope this help.
May 02, 2009 | Acer Aspire 5050-3242 Notebook
Black screen
If the light stays on for longer than about 20 seconds, try moving the lid back and forth, try positioning it in every possible way. If you get an image, even for a second, you need a new LCD cable. If nothing happens, try to get your hands on an external monitor. Plug that bad boy in, if you get the image, you need either a new LCD cable or a new LCD screen. If still nothing happens, then you probably need a new motherboard.
Before you go buying a new MB/LCD/LCD cable, which can be rather costly, open up the back and make sure the RAM is seated properly, sometimes something can jar RAM sticks loose.
P.S. DON'T FORGET TO VOTE
Apr 15, 2009 | Acer Aspire 5050-3371 Notebook
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5050-3242 Notebook Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
