Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca p52927 added dish network reciever now tv wont power on
SOURCE:
  • 1694 Answers
SOURCE: rca p52927 chassis ptk 195 wont power up all of a sudden
Any TV can have a bad solder connection problem after
moving.Unfortunately,the fix may not be easy.
1) pull light box out of cabinet or hire someone to do it
2) slide/tilt for servicing main PC board
3) examine solder connects with magnifier--solder any/all
    bad connects,esp around microprocessor
4) Check horiz output xistor =if ok,re-assemble,test
    If shorted,replace with first quality transistor and solder
    any/all suspect connects in horiz drive circuit,then assemble
  Let me know......T.
Posted on Oct 24, 2007
  • 61 Answers
SOURCE: color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Posted on Mar 07, 2008
Cybertech
  • 149 Answers
SOURCE: RCA MODEL P52927 HELP PLEASE!!!!!!!
can you get me chassis number ?
Posted on Apr 04, 2008
  • 927 Answers
SOURCE: RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Posted on Jun 01, 2008
ladywinn
  • 5138 Answers
SOURCE: 52" rca projecion tv will not come on i broke it down and there is a faint beebing sound comming from the transformer area
Chances are you have 3 bad capacitors 2200uf 16v cp150/ cp111 is 330uf 35v / cp114 is 220uf 35v they are green with gold writing on them.
Posted on Oct 09, 2008
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
I disconnected my dish network reciever for 2 months and now that i connected it again i have no signal, and in dish network they tell me my account is perfect
Hi mendezjuanmy name is Mike Houston of DISH Network and I was going over your post thereare some steps I can give you to do through here. You will want to make surethe TV is set to channel three unless you are running through an input of theTV. The next thing you will want to do is unplug the receiver for 10 secondsand it will power up by itself and acquire the signal and download the programguide, after the guide downloads you will get your programming. I will leaveyou my e-mail if you have any further questions. Michael.houston@dishnetwork.com
Feb 14, 2011 | RCA DISH Network(r) 311 Satellite System
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
Power and record buttons are flashing on reciever and tv is not recieving a signal from reciever
Hello, my name is Nick Franta from DISH Network Customer Support.
Just wanting to make sure this issue has been resolved. If you need assistance let us know!
Dec 03, 2010 | DISH Network ViP 211 DTV Receiver
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
When i watch dish network my theater system wont work ,only if i watch dvd it works
I run my s video from the dish reciever to the tv/satillite s video input and the digital audio to the digital audio input on my reciever. The reciever is a sony V333ES and have no problems at all.
May 30, 2009 | Coby DVD-958 Theater System
I can not get my tv to work with dish network
The RCA guide will not work with the dish remote. You can get the guide to close if you press the White TV button then press cancel. Remember to press the SAT button after you close the guide.
Nov 19, 2008 | RCA 32F531T 32" TV
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
grateful,
kay
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
