Rheem Criterion II - blower works OK w heat or AC, not by itself
The problem appears to be in the internal wiring or control board.
Symptom: If I temporarily connect the red low voltage control wire from the transformer to the green control wire for the fan, a relay clicks on the control board. But the blower does not come on.
I have tried re-seating all five of the blower wire connections to the circuit board but this didn't help.
Does anyone have any suggestions? I'm just a homeowner, not an HVAC specialist. I'm positive the problem is not in the stat or any of the five wires from the stat to the Rheem. Thanks in advance for any thoughts.
  • Stuart Smolkin Jul 12, 2009
    t1m130, thanks for your reply.
    I do know the blower is good; it runs fine when the AC or heat comes on. It only won't run if I change the fan switch on the stat from "auto" to "on."
    As mentioned, the stat is good, the green wire from the stat to the control board has good continuity, and I can hear the relay click on the control board if I jump the green low voltage fan wire to the red low voltage power wire.
    So... I'm suspecting your thought about a burnt spot on the back of the control board is the most likely possibility... unless there's some dip switch setting that deactivates "fan on", so that the fan won't come on even if I choose "fan on" on the stat.
    I hope this clarifies; thanks in advance for any additional thoughts.
  • 86 Answers
Does the blower do anything? turn the power off and take the lead that comes off of the "cool" ( wire from the blower motor) and hook it up to the outlet side of the door switch ( the wire that comes off the door switch and goes to the board) turn the power back on and push the door switch in this will allow 110v to the blower if the blower runs the blower is good
reatach all door switch wire and blower wire to "cool"
disconnect all low voltage terminal wires at control board from thermostat make a jumper with a seperate wire from R to G if it runs it is your Thermostat or the wires inbetween the two
if it doesnt you probably have a burnt solder spot on the back of the control board and will need to replace the board
hope this helps
Posted on Jul 12, 2009
Are there 2 motor in Rheem criterion II furnace? there's chirping sound upper. and a constant humming sound lower in the furnace
Yes. There are two motors. There is a small motor on the inducer assembly that vents the exhaust and there is a larger motor that runs the blower
Jan 01, 2018 | Heating & Cooling
My furnace inducer won't run and no 120VAC from control board. Is it bad?
I'll first check the power distribution board in the workshop.
Make sure all breakers are on.
Then I'll check the wall outlet for power by testing it with another utility.
If you have power then check the fuse on the unit.
Still not working. This needs attention by some more experienced people.
Dec 02, 2017 | Heating & Cooling
My Rheem Criterion II gas furnace makes metal slapping noise when the blower comes on. It is not the blower or the motor.
Is there noise when the inducer motor comes on? The small motor that comes on first. It sucks the co out of the combustion chamber. It comes on first. Then the burner lights then the blower comes on. And the noise continues while it's running and doesn't stop till the blower stops? Is that correct? But it's not the blower wheel? Could it be out of balance and hitting the blower shroud?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
Feb 18, 2017 | Heating & Cooling
Own rheem criterion. pilot light is on but no hot air
make sure thermostat is calling for heat white & red wire touching to buy pass and verify unit is ok and maybe a bad temp control .
Feb 15, 2015 | Rheem Water Heaters
I have a rheem criterion ii plus 2 lxe, the blower fan will not run
Check for a low voltage relay that may be used to power the blower, see if operates. To check a blower motor directly, connect it directly to 120volts. (it might be a 3 speed blower with 4 wires connecting it, so check the wiring diagram)
Aug 18, 2014 | Heating & Cooling
I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
Check air filter is clean , jump out pressure switch see if it lights
Jan 08, 2013 | Heating & Cooling
RHEEM CRITERION II FLAME LIGHT DOES NOT COME ON
1/ overheat stat 2/ fan 3/ diaphrapm valve 4/micro switch when checking fan be sure to check the very small rubberor nylon hose for pinhole best of luck
Oct 29, 2009 | Rheem Paloma PH-20R IFSN / RTG-53PVN...
Are there any recalls on a Rheem Criterion II Model No. RGPH-05EAUER in WI? I have a house that was built in '98. The furnace doesn't dry out the air enough and tons of moisture has built up in the house...
there have been several situations wht rheems as far as control boards cracked heat exchangers cracked inducer assemblys and touchy pressure switches i would call to get a furnace inspection from a rheem dealer
sounds like you really need to buy a portable dehumidifier
Jul 06, 2009 | Heating & Cooling
Rheem Criterion II Furane would not ignite
what you need to do is take and inspect the hose that goes to the pressure switch and make sure that it is not dry rotted. if it is and the combustion blower is running then firsat try to cut the hose down and slip on a better piece of rubber. If not then replace the hose,
Dec 25, 2008 | Heating & Cooling
Heating & Cooling Logo
294 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
