Question about Refrigerators
I have an older ET21DM with an icemaker. Water is
I have an older ET21DM with an icemaker. Water is coming out of the freezer compartment and into the main compartment. Icemaker has been checked and is not leaking. I've taken freezer compartment apart and cleaned out everything. It was full of ice. After cleaning it worked great for a week and now is leaking again.
  • 89 Answers
You need to clean the drain after you clean the ice out you should notice a hole run a piece of wire down the hole a couple of times then flush with hot water
Posted on Jul 12, 2009
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Tip
Water in the freezer compartment
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and embedding it in a block of ice, as well as puddling-up on the bottom of the freezer and eventually blocking the door from closing properly. Because the water seemed to be covering a wider area than you would expect from a blocked defroster drain I didn't believe that my problem was covered by the other FixYa recomendations -and it turned out I was right.
The problem turned out to be that the "funnel" that the water flows through to fill up the ice tray was blocked by a solid piece of ice. When the icemaker would call for more water it would flow down the clear tube (with the open slots on the top) hit the ice and spray/overflow in to the freezer compartment.
The solution was obviously to pop this ice out, but that did require me to remove the icemaker from the wall of the freezer compartment. To do this you
  • remove one screw from the bracket on the bottom of the icemaker
  • Slide the icemaker up and slip it off of the two screws with rubber grommets on them.
By the time I got to that stage I had already removed the basket from the main drawer and removed the pull out tray/basket from the drawer pulls (by simply lifting the plastic tab on the right side and lowering the plastic tab on teh left side). I am not sure if you can remove the icemaker without this step, but I believe so.
Also, if you want to entirely remove the icemaker from the freezer there is only one plug with wiring to undo. As I mentioned above, the water hose doesn't not connect to the icemaker, it ends above the "funnel" and the water drops in. So removal is much simpler than you might expect.
As for the cause of the ice block, I am not sure but I believe it was either because the ice maker made too much ise one time and some cubes could not pop out. When additional water entered the funnel it didn't flow in to the ice tray, backed up, and froze in the funnel. The other thought is that when the door was not closed properly while our grandparents were visiting, the ice melted and subsequently re-froze causing the problem.
on Dec 15, 2007 | LG LFD25860
Icemaker leaking despite replacement
is the ice maker actually leaking or do you have a crack in the ice bin allowing it to leak from cubes?
Aug 27, 2015 | Refrigerators
Whirlpool fridge making a low, intermitant groaning sound
Is it coming from inside fridge compartment or freezer compartment or from outside back. If it is from freezer compartment and you have no water line connected to ice maker. Then it might be just your ice maker trying to go into fake harvesting mode. Make sure the Icemaker is off. Icemaker arm should be up.
Oct 14, 2014 | Whirlpool Refrigerators
Loud buzzing from freezer
icemaker wont work in fridge. the buzzing sound might be the water solenoid operating and waiting for water level sensor to be happy. solenoid will make a loud harsh buzz check water supply to back of freezer and see if there is a lever on icemaker you can lift up to turn off.
May 16, 2013 | Frigidaire Professional 27.8 Cu. Ft....
Replace icmaker on kenmore
Unplug refrigerator. Take a moment to examine how the icemaker is positioned in the freezer compartment prior to proceeding (e.g.: water inlet tubing coming into the icemaker, etc.). Remove or loosen (where applicalble) screws holding icemaker. Unplug icemaker's wire harness connection. install new icemaker by reversing the screws harness, etc. Make certain that the new icemaker is in the "on" position. Plug the refrigerator in. Allow approximately 6 to 8 hours (some models take fewer or longer timeframe) for ice production.
Feb 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker -- not all cubes freezing, running water into rear portion of cube storage tray.
Purchase an inexpensive temperature monitor. Check temp in freezer. Ideally, you should have from 0 degrees to 10 degrees in the freezer. The icemaker calls for water at a certain temperature. There may be an issue with the icemaker, which has a "u-shaped" heater underneath the icemaker to loosen the ice prior to dropping ice in the ice bucket. Or, there could be an issue with your freezer control assembly (typically located in the fresh food compartment). Contact an appliance service company.
Feb 10, 2010 | Amana Refrigerators
Whirlpool ET21DMXDW05 top freezer. icemaker not working
Give it some more time. The icemaker has an internal thermostat and it will not come back on until it reaches 16 degrees. It takes a while after it gets warm. if it doesn't start functioning in a few more hours you may have other problems. Hope this helps
Jun 07, 2009 | Refrigerators
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Ice Maker floods floor and freezer compartment
You may not have got the supply tube all the way into position so I would check this first. If the water is running down the back wall of the freezer compartment at a higher level than the icemaker the problem is not with the icemaker but with some break in the supply chain. If the water is overflowing from the icemaker then it could be the timer cycle on the icemaker or the water inlet solenoid valve at the back of the cabinet (compressor side). Water leaks need to be traced back to the highest point ( I know how obvious that sounds but sometimes we all miss the obvious). Hope this is of some help.
Aug 16, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
