Question about Kenmore 84152 Electric Dryer
Whirlpool lep6848awo runs hot
Whirlpool clothes dryer lep6848awo runs too hot on any temp setting
  • 89 Answers
Check the blower wheel make sure it is working properly if it is check the vent make sure it is not crimped or clogged
Posted on Jul 12, 2009
Whirlpool dryer times jump on high temp from 50 to 29 takes three cycles to dry cloths.
Check that the heating element is working. Then check the exhaust flue of dryer to make sure that it is not clogged. If it is the clothing will stay damp and the room housing the dryer will get hot and muggy.
Oct 27, 2016 | Whirlpool Dryers
My Whirlpool Duet DRYER--the clothes are wetter than when I put them in & there is now water sitting in the bottom. It does have a steam setting, but I'm not using that one. It's 4 years old.
Check your exhaust vent! If you have an obstruction, the steamy air will have no where to go, then your air-conditioning temps inside can cause the water to condense in the vent tube... Even if the vent is just open to the hot summer air and the clothes sit in the machine the difference in temps between inside and outside can cause these symptoms...
Jul 25, 2016 | Whirlpool Duet High Efficiency Gas Dryer...
No matter where I set the temp control or how little drying time I set it for, it always dries fast and hot
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 06, 2011 | Dryers
My dryer is running hot but doesn't dry the
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
MY WHIRLPOOL DRYER IS OVER HEATING
heatman101
Jul 31, 2011 | Whirlpool Dryers
Model MDE4000AYW, Dryer runs full hot no matter where I set the temp selector. It appears the temp selector may be bad? The sliding selector seems to have 0 resit.(open cir) white to black. Thanks for...
heatman101
May 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Dryer hets to hot
I would check the temp at your outside vent while the dryer is running temp should anywhere from 180 to 225 at the high end and should cycle down from there so u should get like 225 then will drop down to 90's then come back up to the high temp and check on all temp settings. if it does not your operating thermostat may be bad go back over the instructions that came with your thermostat kit to double check your wiring the tech sheet should be in the control panel with the wiring diagram.
Feb 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Kenmore 84152 Electric Dryer Logo
113 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
