Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi rear projection
Where is the convergence board located in my 51" rear projection so that i can see if anything is broken. I had a price of 250. to have it fixed. thanks
  • 4,402 Answers
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Posted on Dec 05, 2007
Hi, i have 2003, 57 in" hitachi rear projection tv, model #57G500A. the problem is a thin wavy line across the top and bottom of the screen. could you tell me what would cause that.thank you for your...
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,the tv convergence board have 2 dead convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Mar 21, 2011 | Hitachi 51F500 51" Rear Projection...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F500A blue is out of focus, and will not let me adjust it in manual convergence. Please advise!
Your convergence board is on the fritz! Try contacting and see if they can help you!
Feb 06, 2010 | Hitachi 51F500 51" Rear Projection...
How do I fix a converence problem?
First try using Autofocus. If there is a convergence problem this won't fix the problem.
Try using the convergence alignment procedure from service manual.
Here the procedure that works on most Hitachi rear projection.
Here the grid with convergence problem
If the procedure does not work, then the two STK392-110 on convergence board must be replaced.
Before replacing the ICs you can test the pico fuses located on convergence boards. Simply read ohms to test if they have continuity.
Better also testing components on convergence board like resistors located at the base of STKs.
After removing the old STK, the new ones must be re-soldered using cooling paste.
Price for single IC can is about $8/$20. I think
STK392-110 on this model can be better replaced with STK392-150. I suggest contacting the seller on this.
The service manual is available here.
Jan 12, 2010 | Hitachi 50SBX78B 50" Rear Projection...
My Hitachi TV Model #51F500 is showing shadows and double lettering (in other words a terrible picture). Please help.
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Nov 05, 2009 | Hitachi 51F500 51" Rear Projection...
Tiny Mirrors Around the Screen of the Hitachi 51" Rear Projection
OK.. These are photo-sensors for auto-convergence function and without these sensors, auto-convergence function will not work properly.
Jan 02, 2009 | Televison & Video
average price for the repair is around 400.00, sounds like there is an extra charge because of the distance involved.
Jun 06, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510 screen wont turn on
lighting can effect anything and everything, call insurance and get replacement value for set.
Nov 16, 2007 | Hitachi 51F500 51" Rear Projection...
bad solder connections on convergance board solder the connections if this does not work then replace them
Nov 15, 2007 | Hitachi 51G500 51" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
128 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
