SOURCE: Whenever i try to install
To fix that problem,
Open your computer in safe mode,
open a command promt
Register the following DLL s
it should be in the %system root% \ system32 folder
just type the following statements one by one and see you got success information popup
regsvr32 licwmi.dll
regsvr32 regwizc.dll
regsvr32 licdll.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 msxml.dll
regsvr32 shdocvw.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
regsvr32 cryptdlg.dll
then try to restart,
SOURCE: I bought a LENOVO B
Please note that installing an operating system on an OEM machine OTHER than what was factory-installed on it may void either phone support for the customized OS or the warranty itself.
Lenovo Machines, like most new OEM models are set, by default to run their hard drives in AHCI mode for better performance & power management. Go to the computer's system setup F1 or Del while the computer is starting up to locate the Power, Hard drive or System configuration (Lenovo computers have different System Setup formats for each model so you'll have to navigate around a bit since they may be labeled differently).
Once you find it, you have to change the setting from AHCI to IDE or Compatibility, whichever option is available (once again, each model has a different format & labeling convention). Save the changes & exit the setup & retry the installation. Should work.
