Question about HP Pavilion MX70 17" CRT Monitor
My mouse isnt working it has a hard time moving to the left it is difficult to placethe pointer where i want it like to open up mail the mouse is connected to the only port available on the tower ps/2 when i check it i get a message that the mouse is detcted and working ive had this problem for quite a while i bought anew mouse thinking that was the problem (its a fellowes) but it still isnt working HELP!!!!!!!!!!!!!!!!!!! Kathy
  • 4,102 Answers
Re: My mouse isnt working it has a hard time moving to...
Are you using the mouse on a mouse mat because you get this prob if the place you are using the mouse is greasy or dust are you using an infra red mouse or does it have a ball in the bottom if it has a ball in the bottom a rubber one undo the clip holding the ball in tip it up so the ball comes out you should now see three rollers the one at top is up n down and one at side is left and right the third is just to hold the ball against the other two all these rollers should be smooth usually they get a build up of dirt in the middle of each roler scratch this of with your finger do this with comp on and try rubbing the rollers up and down and see if the mouse is moving on the scrren how it should clean all three of these rollers check theball is clean and not greasy if you can move the pointer using you fingers on the rollers then you know the problem is not your mouse so put back together then the only other thing could be wrong is the mouse mat you will need to replace this or clean it properly try using the mouse on a book and see if this is any better if you have infra red mouse you dont need mouse mat and should have no problem if you still have problems post back and i will try again hope this is some help to you ............................................
Posted on Nov 15, 2007
0 characters
3 Points
Mouse cursor disappear on hp w2371d
See this...
If it only disappears when you move it left or right off the edge of the screen, your video software may think you have a second monitor. Tell it different.
Aug 04, 2014 | HP W2371D 23 Full LED Monitor 16:9 5ms...
Mouse pointer disappers
I've seen this happen a couple of times when Word uses the initial preview "Read Mode" or Protected View . Try changing the mode by clicking on the View tab and changing the mode to Print Layout. When it happens to me, that seems to do the trick. If you don't want Word to use the Protected View, go into the Trust Settings for Protected View and uncheck the options in there...this may also keep it from happening in the future...good luck! :-)
Apr 24, 2014 | HP Pavilion 23xi 23" LED LCD Monitor -...
I have an l2410NM monitor. It has been working perfectly but this morning, I receive no picture at all. The screen is black but the arrow pointer from the mouse is visible and moves about aw normal. ...
If you can see a mouse pointer, then your monitor is not the issue.
Your operating system is not loading properly. You will need to have you system looked at to determine why your operating system is not loading correctly.
Mar 16, 2011 | Westinghouse Computer Monitors
On Screen image is moved to the Right side of the monitor so I can't see any of my slide bottons
What application? what operating system? Have you tried placing your pointer on the top bar of the window and holding down your left mouse button, drag the window over?
Apr 12, 2010 | LG Computer Monitors
LCD monitor not working right
This is 2004 model, it may not be worth putting money and time into repairing a 15" monitor. But you can at least look inside for any damaged, burnt components, lose connections, etc. otherwise to do a component level repair at the shop will not be worth it.
See eample of what usually goes wrong with LCD monitors:
Apr 05, 2010 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
Image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Mouse Control
see if its plugged in properly or try connecting it in the ps/2 port and install the driver if you havent done that yet
Sep 27, 2007 | HP Pavilion MX70 17" CRT Monitor
Monitor display is totally moved to the left.
Start >> Control Panel >> Display >> Settings >> Advanced >> Intel(R) Extreme Graphics 2 >> Graphics Properties >> Hot Keys >> Check mark on Enable Hot Keys >> APPLY.
Now press ALT + CTRL + up (ARROW).
Make sure after doing this uncheck on Enable Hot Keys.
Feb 18, 2007 | HP Compaq S9500 19" CRT Monitor
HP Pavilion MX70 17" CRT Monitor Logo
381 people viewed this question
Top HP Computer Monitors Experts
Ivan Bernal
Level 1 Expert
Tony Isted
Level 1 Expert
Elizabeth Mescall
Level 1 Expert
Are you a HP Computer Monitor Expert? Answer questions, earn points and help others
