Question about Panasonic PT-47WX49 47" Rear Projection Television
Cannot adjust blue convergence on panasonic pt-51hx42
    Problem Solver:
  • 11 Answers
If you cannot adjust it then it is broken.
You can find websites online to change out the convergence amps, or you can pay a pro to do it, usually about $300
Posted on Jul 12, 2009
Having green and pink lines on the bottom and curving in the middle of the tv. What do you suggest for the fix?
It sounds like your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 26, 2011 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic pt-51hx42 convergence problem
Replace Both STK ICs,they are big black ICs and will have PN# on them
Mats sales ICs 1-800-628-1118
Feb 15, 2011 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic pt-51hx42f replaced 2 convergence chips and 6 convergence resistors. still can move any of the convergence set-up arrows. was told it might be the pico fuses. But I cant locate them on the...
No thats not the Problem you have to know HOW TO ENTER SERVICE MENU Their is a Long Step in getting into the SM
if not done correctly you can really Mess this TV up! Once you Enter the service menu then you can go to convergence and adjust
to correct Pattern,Then you Must Exit correctly with the Save Mode to Save alinement or you will have to adjust all over again.
Sep 20, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-4743g
CK hori out put Transistor, next to or behind that part is a small blue capacitor high voltage 2k volts see if it has burt pin hole if so replace it also resolder convergence plugins and FBT.Your STKs could need replacing they are big black ICs will have part number on them if 110s use 180s Call Mats for parts 1-800-628-`1118
Aug 14, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Convergence line will not move to match cross hairs
the green line will not move. it is stationery and red and blue have to adjusted to it
Jul 20, 2009 | Panasonic PT-51HX42 51" Rear Projection...
I have a panasonic pt-51hx42. I was just
your convergence power supply blew a fuse & probably one if not both of the STK ics. Normally when this happens the short takes out the low value resistors connected to the ics.
it is common practice in the shop to replace both STKs and resistors
Jun 09, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Samsung:pcl4515r
You may still one more resistor opened , samsung most of the time its 2 low ohms but can be 3 it will be same value as other 2. I think they are 2.7ohms or 3.9 How to Enter Service Menu for convergence Turn TV off Press Mute 1-8-2-power now you should be in convergence use vol- and vol+ to select an item Use mute and menu to adjust when done Press ADD to save adjustments made.
Dec 12, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Think this is worth fixing?
trust ME when i say setting convergence after doing repair takes alot of time to do /you can damage set if you do not have service codes and values/ you also must have the hand unit that comes with set in order to even get into convergence circuit, call your repair shops ask if they have a good blue tube for set and how much would it cost to repair?ARE you sure blue tube has been removed from set.?
Jun 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
