Question about Canon i850 InkJet Photo Printer
Printer is printing stripes instead of a solid color
  • 3 Answers
Try going to your Control Panel, choose Printers, choose Canon Inkjet and then choose Properties. Then choose Maintenance and then either Nozzle Check or Printhead Alignment. One of these might solve your problem.
Posted on Aug 02, 2009
5 Suggested Answers
SOURCE: my canon i860 is printing funny stripes on all colored docs
I am having the same problem. Does anyone know the solution to this one?
Posted on Oct 27, 2007
mikesagenius
  • 24 Answers
SOURCE: Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Posted on Jul 26, 2009
danmats
  • 195 Answers
SOURCE: Color printer printing out 2 parellel stripes on the paper
clean your printer with a soft brush.....then wipe rollers with a damn cloth...
Posted on Oct 06, 2009
anas12ka4
  • 76 Answers
SOURCE: color prints out photos in stripes
if you are getting stripes in photos then there is a problem with cartrige, take a cotton swab and dip it in water and clean the cartridge head and then try, and if still the same problem exist replace the color cartrige.
Posted on Feb 14, 2010
Xerox 8500 phaser prints brown tint
Most likely the cyan ink is burnt. If the ink sticks are left unused (printing more black than color, this will happen.
Print the test pages for PQ troubleshooting from the control panel and examine each print. Cyan will probably have very dark streaks down the page, magenta should look normal, and yellow also will have dark stripes. You need to replace this burnt ink, and the only way is to print. From within paint (or similar accessory in other OS) Create a full page of cyan, and print about 100 - 200 pages, or until the cyan starts to clear up. Yes it is a waste, but much cheaper than a print head, Do this for yellow as well.
Apr 15, 2014 | Xerox Phaser 8560DN Laser Printer
Color is stripey instead of solid
Run the "clean printhead" from your computer's printer utility.
It could also be that you're printing using "draft" or "low" quality settings
Apr 02, 2010 | HP DesignJet 110 Plus InkJet Printer
There are magenta horizontal stripes going across all color prints. I have done nozzle checks and cleaning but still the 6M and 6C are not solid colors as they should be.
try checking for dirty contacts where the ink cartridge connects to printer (where it sits, the gold pins or somethin).
If changning cartridges dont work it probably your carriage ribbon
Aug 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Colors aren't blending
We have a problem,after the calibration on the begin the printer gives an error: "Color regist. error",but the toners are full ! How to resolve?? Thanks in advance.
Mar 05, 2009 | Ricoh Aficio CL2000 Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Thought I would ask you, since u have answered Ricoh CL3500N
According to the maintenance manual, broken lines are caused by the "dithering" setting. Also there is an in depth color calibration process you can execute. Have you checked the PCU unit?
Here is the maintenance manual:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/cl3500/cl3500en.htm
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Mar 25, 2008 | Xerox Phaser 8550DX Laser Printer
My canon i860 is printing funny stripes on all colored docs
Oct 21, 2007 | Canon i860 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
361 people viewed this question
Clive
Clive
old marine
old marine
