Question about Frigidaire Washing Machines
Frigidaire washer spins but won't agitate
My frigidaire washer model FWX833AS2 (top loading) will fill but will not agitate. If i try to turn the cone to the right it starts making a really loud noise. If i advance to the next cycle, it will drain and spin just fine. I'm not sure where to begin, I hope this hasn't been posted before. Any help would be greatly appreciated, thanks.
    New Friend:
When you try to spin the Agitator dose it spin freely both ways if so the DOG EARs are stripped and need replacing Take cap off top off agitator to access the bolt holding the n in place and the Agitator off
Posted on Oct 22, 2017
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
SOURCE: Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Posted on Nov 24, 2007
  • 249 Answers
SOURCE: Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Posted on Nov 25, 2007
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
Will not agitate or spin, does fill with water. Just happened. GLWS1233A Frigidaire top load
I replace a new solenoid, I started to get my cold water but then, I replace a new lid lock and it stop agitating. Could you please help me.
May 16, 2011 | Frigidaire GLWS1233A Top Load Washer
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
Frigidaire top load washer will not drain Model # FWX833AS2
Check your lid switch for continuity.
No continuity, replace the lid switch.
Mar 12, 2009 | Frigidaire Washing Machines
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer will fill, drain, and run a complete cycle but will not agitate or spin
sounds like the motor control board is bad. you could test the motor to see if it ohms out ok, the diagram has the readings. The diagram should be on the side panel (inside the cabinet) on the lt side in a brown envelope.
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Probably a stripped gear in the transmission.
Jan 28, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
279 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
