Question about Sony RCD-W10 2-Disc CD Recorder
Error message "DATA DISC"
My CDR W100 has worked absolutely perfectly for years however recently I am unable to record music as I get similar issues when trying to finalize and, more recently, don't get to the finalize stage as I am greeted with the error message "DATA DISC" when I try to record anything.
I have read other forums that all seem to suggest that this is due to the brand and/or type of blank CD I am using. I would appreciate any comment and advice.
  • peterernest Jul 15, 2009
    Teqman: Hadn't seen your solution however I had never believed the 'type of disc' response though had heard it so many times on occasion had started to believe it!
    I shall attempt your idea and if \i live through the experience, I shall report back...
    thank you
    Scholar:
  • 75 Answers
No No No and No again this disc issue makes me laugh. Look lasers are sensitive but after a while the power output level decreases to the point where the disc may still be able to be read but recording/finalizing is impossible.
Hmmm, I think I may have to point people to a link on this site as I've answered this question many times. However, here we go. As I previously stated the power is down on your laser specifically the recording laser. A potentiometer adjustment is required but this necessitates the drive mechanism with laser to be removed from the player. If you feel happy to do this, with the drive removed look on the underside of the laser unit and you will see two potentiometers (2 crosscut screw like objects). I don't know the layout of your unit but it's normally the pot on the right that needs to be adjusted clockwise by an eigth of a turn which increases the power output thus solving the issue completely. There's always a little bit of play in these things so it is safe to do this. Good luck
Posted on Jul 14, 2009
  • teqman
    teqman Jul 15, 2009
    If you feel confident enough to do this it really does work. If you don't it may be worthwhile having a professional look at it for you. Problem is though they ae more likely to come out with the lame answer your laser needs replacing, it's easier for them to make more money that way.
    If you wanna make sure things run more smoothly it might pay to take photos of the dis assembly process thus installing more personal confidence. Before you make adjustment on laser perhaps you could post up a pic of the unit showing the potetiometers for me to look at.
    Good luck
  • peterernest Nov 12, 2010
    I have been intending to try this repair on my CD recorder since reading this answer one year ago. My intention was to attyempt the repair and photograph the stages in the hope of benefiting others with this issue.
    I have not yet attempted the repair but since read an awful lot about this unit including reading the manual thoroughly. I now believe that this Sony unit is a very clever unit, it is very particular about what items it will copy and very particular about what it will copy items on to. I have invested in Maxwell XL-II 80 Music CD which do appear to work perfectly with this unit. When/if they begin to fail I shall resort to carrying out this repair.
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Disc types that have worked for recording in the past are getting a "Not Audio" error upon reading. Specifically HHB CDR80's.
hi, i would try not using cdr discs. alot of older decks had issues reading "r"discs try cd'made for music not data. that should fix u up.
Apr 19, 2016 | Yamaha Natural Sound Cd Recorder Cdr S1000...
When I insert a blank disk, Im getting a message saying "No audio". and nothing will record. Wot to do???
It's a data disc, not the required CDR-AUDIO or -MUSIC disk it needs to record.
Feb 16, 2011 | Marantz DR-700 CD Player
For sony rcd-w500c/w100 won't go to record mode.
Make sure you're using CD-R AUDIO or MUSIC blank discs. It won't record onto data discs.
Jul 20, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Jan 27, 2009 | Denon CDR-W1500 2-Disc CD Recorder
Wrond Disc
The disc you need to use to record is "PHILIPS CDR MUSIC". That is what it should day on the top of the disc. On the left side of the disc, it should say "DIGITAL AUDIO RECORDABLE". I spent a lot of money buying the wrong discs before finally finding the correct one. So I know your frustration!
Apr 05, 2008 | Philips CDR600 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Want record
Are you using 'music use' cdr?'s You need to use an audio CDr, data or computer CDr's will not work in this machine.
Aug 27, 2007 | RCA CDRW121 2-Disc CD Recorder
Sony RCD-W10 2-Disc CD Recorder Logo
223 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
