Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP 6210 power on is wonky
The first time I press the ON button I get a cursor crawling across the LCD and then it goes dark again. The second time I press ON it initialises properly
  • 4,402 Answers
When there are low power problems, the all-in-one may turn off repeatedly. Low power is a common problem in many home offices, because of the number of electronic devices concentrated in one area. To correct the problem, follow the steps below:
  1. Unplug the all-in-one power cable from any power strip or surge suppressor. Plug it directly into a wall outlet.
  2. Verify that the computer power cable, the all-in-one power cable, and the power strip have a three-prong plug.
  3. Reduce the number of devices sharing the power circuit in the office or home wiring.
  4. If the problem still exists, service your product.
Posted on Jan 10, 2008
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
I have an HP Officejet 6210 All-in-One Printer Whenever I turn the printer on now, it will draw in a piece of paper, and spit about half the paper out to the "out" tray and then promptly...
To me is seems issue with the hardware try to RESET the printer and for doign that follow this
1. Unplug the power cord from the back of the printer while the printer is ON
2. press and hold # and 6 button at the same time
3. while holding them plug in the power cord
4. When you see the lights on and a progress bar on your LCD screen release the buttons
it will take a minute or 2 and will reset the printer and it may fix the problem
Apr 17, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I want to restart of shut down my HP iPAQ rx3115
For the HP iPAQ rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Mar 01, 2011 | Cell Phones
Monitor goes dark after about 2 seconds
I have the same monitor, its a power supply problem from the computer most likely. check the cable connections etc... I would get a service call from an authorized dealer near you ... about $120.00. Hope this helps:)
Jul 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp f1903 flat pc monitor goes black after 5
I was given a faulty f1703 by someone as it was out of warranty, had no help from HP and bought another brand replacement.
Same problem everyone else seems to be having. Press the on button, came on for a second or so and then went blank. Press button again, turn on again and the same happened.
I managed through trying time and again after pressing on to quickly press menu, then go down to Factory settings, press select, go down to Yes and press select again. This reset to the Factory settings and it seems to be working okay. Been like this now for about a week. I don't know how long it will last - if it goes again will try re-soldering. Guess I won't be buying HP products as this was a part of a very expensive system.
Apr 29, 2010 | HP W2007 LCD Monitor
From the manual:
1) Press Setup.
2) Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3) Enter the month, day, and year by pressing the appropriate numbers on the keypad. Depending on your country/region setting, you might enter the date in a different order.
The underline cursor is presented initially beneath the first digit; it automatically advances to the next digit when you press a button. The time prompt automatically appears after you enter the last digit of the date.
4) Enter the hours and minutes.
5) If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM. The new date and time settings appear on the control panel display.
Note that if your HP all-in-one loses power, you will need to reset the date and time again!
Mar 14, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My hp officejet 6210 has a message reading remove and check color cartridge? And I do what it says and it just repeats and repeats?? Whats wrong with it? Should I buy a new color cartridge?
Hi you can try this may work.
In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
And try this.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
For me, it worked when I did this:
1) With the printer powered off but connected to a power source, press and hold the Stop/Reset button for 4-5 seconds.
2) Without letting go of the Stop/Reset button, press and hold the Power button. Then, press the Stop/Reset button two times without letting go of the Power button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Ibook display problem
You can reset the pmu this might help to stable the display,this is only used as a last resort and not a possible solution.
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the iBook computer.
Oct 07, 2009 | Apple iBook G4 Mac Notebook
6210 Stuck in self test mode
Perform the steps provided below.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer Error Message HP AIO 6210 printer
If you find the lights flashing, we could try resetting the printer.I have explained the reset procedures below
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
