Question about Equator EZ 3612 CEE Front Load Washer/Dryer
Handle broken Whan i wanted to open the door i ended up with a broken handle in my hand so i can't open any more the door.Is there a solution to open the door?How can help my,because most of the people i called don't repair this brand
I've been using a small-sized flat-head screwdriver (bout 3/16 wide). if you look at the handle area - you can see where the spring/notch is between the rim and where the handle used to be - it's annoying the first few dozen times but now it's just 2nd nature with it - pops right open every time with ease
Posted on Dec 08, 2011
It got broken on me also so I'm using a knife and a fork :), the knife for pushing in what's remained from the handle and I stick the fork between the door and the rim and the door pops up. It works on mine :)
Posted on Mar 09, 2008
2006 Mercedes 560 SL interior door handle
1st you need to open door, remove plastic trim on inside of door by the handle, there is a hole where a 25 torx screw is holding handle end cap, pull door handle in open position, slacken screw until end cap is loose, remove end cap & slide door handle to rear of door out comes the handle, check with torch for any broken parts
Feb 11, 2015 | Mercedes-Benz SL-Class Cars & Trucks
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
Drivers side door will not open by using the inside handle
The door inner panel will have to be removed, to see if the handle is broken or the rod connecting handle to latch has come loose. When you get the panel off, you will see if it's the handle or the rod (held in place with plastic clips at both ends). If it is the rod, pull off the plastic water shield to work inside the door. The plastic can be resealed with new adhesive.
Feb 19, 2013 | Cars & Trucks
Rear door handle broken. Mazda mpv 2001. lock works fine.
The relay rod inside the door has broken (not likely), one of the retaining clips that hold it in place are broken (most likely) or the tab on the door handle assembly is broken (again not likely). to gain access you will have to remove the door panel. You did not say whether the handle you are having a problem with is the interior or exterior but to remove the door panel you will need to have the door open, you might want to purchase a Haynes or Chilton manual for your car to get the proper instruction if you have never removed one before.
Dec 12, 2011 | Toyota Cars & Trucks
How do i remove the handle of my whirlpool fridge?
you may need a new door,,or use the top door just up-end it and put it on the bottom?
Jul 04, 2010 | Refrigerators
Driver door will not open using inside door handle. outside handle works fine. its almost like the door lock lever is set to lock, no real resistance when pulling lever. pulled door panel and everything...
Hey there,
I have the same problem, for me it was the metal ball at the end of the cable, on the inside of the door, was broken off. To me it seems it needs to have that cable or the clip attaching the cable replace. I took off the door panel and used a mirror to peer inside. You'll have to unscrew a plastic black cover which hides the cables near the mechanism.
Hope this helps
Jun 09, 2010 | 2005 Hyundai Elantra
Rightside interior door handle not opening door
It could mean the rod connecting the handle to the latch has broken. You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. and you can access the innards of the door
Sep 04, 2009 | 2002 Kia Sedona
Driverside door handle frame is broken and cannot open the door
check handle is ok or broke
check behind handle shaft if it is came out from- handle point
Mar 21, 2009 | 1991 Honda Accord
Cannot open door from inside on front driverside
29 cent part my fix your problem. There is a nipple on the interior door lock lever that fits into a slot on the door handle lever. Look at passenger side to compare. The nipple is covered with a plastic spacer that may come off. The spacer keeps the lock nipple snug in the handle lever slot; pull the handle lever, it engages the lock lever, opening door. I bought a .29 cent aluminum spacer (#8x1/4 x 1/4) from Orchard hardware. Take needle nose pliers and slip the spacer on, then super glue. Unfortunately if lock lever (where riveted) is badly worn, then it may pivot upward instead of perpendicular to the door, thus defeating new spacer. But you may now be able to open door by pulling handle lever and lock lever at the same time. If you need to replace door handle, others on this site have suggested that you not replace metal frame that door handle is mounted on, but drill out rivets that hold door handle mount.
Jan 29, 2009 | 2001 Lincoln LS
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
291 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
