Question about Hayward SAND FILTER, PRO SERIES
I have a Hayward S200 sandfilter. The settings for the control valve are worn off and I cannot read the location for the settings. Can anybody tell me what the settings are starting at 12:00. Thanks
    President:
  • Hayward Master
  • 1,378 Answers
1F ERROR CODE appears on Hayward model # h250PED2
Code Fault Diagnosis Step Remedy
None
Open FC3 and/or
F1 Fuses
1. Check for faulty Gas
Valve wiring.
Inspect Gas Valve wiring. Ensure insulation on wiring is not worn. If
OK, proceed to step 2.
2. Verify that Gas Valve is
not defective.
Mesure for resistance across Gas Valve terminals and between each
terminal and ground. If short exists, replace Gas Valve. If OK, proceed
to step 3.
3. Check for faulty Control
Module wiring.
Inspect Control Module wiring. Ensure insulation on wiring is not worn.
If OK proceed to step 4.
4. Control Module is
defective.
Replace Control Module.
Ignition Failure 1. Ensure gas supply shutoff
valves are open.
Ensure that main gas shutoff installed adjacent to heater is open. Ensure
that knob on gas valve inside unit is in ''on'' position. If OK, proceed to
step 2.
2. Check for low gas supply
pressure
Ensure inlet gas supply pressure is between the minimum and maximum
values indicated on rating plate. If OK, proceed to step 3.
3. Check for faulty flame
sense wiring or connection.
Inspect flame sense wiring. Ensure wire harness terminals are securely
fastened to flame sense and to control module. If OK, proceed to step 4.
4. Check for faulty gas valve
Inspect gas valve wiring. Ensure wire harness terminals are securely
fastened to spade terminals on gas valve. If OK, proceed to step 5.
5. Check for gas valve
failure or gas valve relay
failure.
1. Measure voltage across gas valve during trial for igintion. If 24VAC
is present and gas valve does not open, gas valve is defective. Replace
gas valve.
2. If 24VAC is not present, gas valve relay on control module is
defective. Replace control module.
6. Check for blockages in
gas orifices and burners
Inspect gas orifices for blockages which could prevent gas flow. Remove
and inspect burners for blockage
Jan 02, 2015 | Hayward H Series Electronic Ignition...
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
The ring on the head of my hayward filter that shows backwash rinse filter etc. Is worn can this be replaced
Yes it can. Do you mean the text is worn and hard to read? you could replace the top, but if it's working, I'd engrave new words on it you can read.
you can go to www.haywardnet.com and find parts. Try this link to one of the valves:
http://www.haywardnet.com/products/Manuals/pdfs/manual18.pdf
There is more than one model number
Jul 04, 2010 | Hayward SAND FILTER, PRO SERIES
Problems with hayward vari flow valve.
It sounds like you might just need to replace your valve. They are fairly inexpensive. Try contacting this company. They will be able to tell you exactly what you need to do (free advice) and will have the parts necessary if you do need to buy a new pool filter or new parts.
Backyard City Pools 888-751-0101 or www.backyardcity.com
Just let them know that you need to speak with the person in charge of pools. He will be able to help.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Is there a way to recalibrate salt reading?
Maybe... Page 40 of the Operations Manual does have some adjustment features. If you have a manual, you can download one here: http://www.haywardnet.com/products/Manuals/pdfs/Manual252.pdf
Apr 10, 2010 | Hayward Aqua Logic PS-16 Automatic...
Why should our new sandfilter (installed in May)
THIS IS A DEFINITE FLAW IN THE FILTER CHANGING THE SETTING WHILE RUNNING WILL DAMAGE THE SPROCKET SETTING UNDER THE HANDLE NOT CRACK A SEAM THE ONLY OTHER REASON WOULD BE IF FILTER HAS FROZEN
Aug 03, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward H300 heater runs but will not heat water
Your internal by-pass could be stuck open or the disc could be worn to the point of letting water pass too fast. Or your thermal control valve could be stuck open. These are both found in your water header going into the heater. Hope this helps, good luck.
Jul 02, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
Hayward SAND FILTER, PRO SERIES Logo
622 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
