Question about RCA RS2041 CD Shelf System
No Auxilliary port
My remote has a button that says AUX, but there is no place (as far as I can determine) for any outside add-on. Am I overlooking something?
Re: No Auxilliary port
Look for a little door on front at the bottom below the CDs - open the door and you will find both the ear phone jack and the auxillary connections.
Posted on Oct 29, 2008
0 characters
3 Points
I connected an aux to it i dont know how to like put it in aux mode i cant find it
The MHC-GX9900 has several audio input ports (RCA L/R) on the back of the unit. Press the TV or Video/MD buttons on the left side of the amplifier part of the unit. Alternatively, these are accessed in turn by repeatedly pressing the Function button on the remote. The TV input is the top one of the pair of inputs. The front ports are audio out to headphones and a pair of microphone in ports.
I hope this helps.
Nov 12, 2015 | Sony MHC-GX9900 Shelf System
How to remove timer
If the unit is controlled by a remote, the symptom you are experiencing could be cause by a function only available on the remote. I discovered this with my Yamaha 5-CD disc changer. However, my unit doesn't have an integrated Stereo. Your unit may mean that the remote handles more features. Search for a button that says MODE or AUX. If you still have the User Manual with the system, check to see what these buttons describe as controlling which features. Check back with me.
Jan 27, 2014 | Venturer Home Stereo AM/FM Cassette 5 CD...
I have a Bose Wave II radio. Never a problem until today. No sound from radio, CD, aux. Display works fine. Remote works. Have tried unplugging and plugging back in. Tried turning volume up, muting and...
in your boss amplifire system hardware problem in u try to mute and volume button please check aux port also if found no output sound then go boss service station there are some hardware problem
May 16, 2012 | Bose Audio Shelf Systems
NEED operators manual for ITRR-501 retro 5 in 1. lost mamual. NEED TO KNOW how to record to CD Disc. Also will it record fro records to disc and record cassett to disk. PLEASE SEND me a manual. OR a zerox...
The unit will record to CD from the turntable, cassette or the AUX port. Place a blank CD-R or CD-RW in the CD tray. (Note: CD-RW discs may not play on other CD players.) Press the Phono, Tape or Aux button to select your audio source for recording. (For Aux, you will need to connect the source device to the AUX port in the back of the ITRR-501.) Wait for the CD disc to load and check for any indicator lights (you should see the "NO TOC" and "CD" or "CD-RW" lights lit). Select your Track increment (or Auto Manual for unattended track formation).Press Record button and the up arrow to adjust the recording level.
If you are recording from an LP, put the tone arm down on the record. For all sources, press Play. Press Stop to end recording or Pause to temporarily break the recording. Press the Track Increment button to advance the track number if you are doing so.
To finalize your CD-R to make it readable on all players: after stopping the recording, press the Finalize button.
The manuals for Innovative Technology products are available here: . The products are listed in alphabetical order. The direct link to the ITRR-501 manual in English is .
I hope this helps.
Sep 19, 2011 | Innovative Technology ITRR501 Audio Shelf...
How do i switch to aux with out remote on sanyo dc-mm5000
You can select the aux by pressing the video button one the frond panel of your system.
Jun 09, 2011 | Sanyo DC-MM5000 CD Shelf System
I can't find the remote. How do I select the aux imput on the back of the unit to accept a nd play an external source?
According to the 'manual', the NEZ30 has buttons for certain functions ONLY on the remote. The FUNCTION button is one of them. Bummer.
Jan 27, 2010 | Audio Shelf Systems
Is their an aux function for a sony cmt-ne3
What if I no longer have the remote?? Is there another way of accessing the MD or "aux"??
Nov 13, 2009 | Sony CMT-NE3 CD Shelf System
Mp3 player
you'll need the reqired plug for earphone plug or rca plug.depends on the socket.mp3's usually use the earphone plugs because it's small.after having all the necessary plugs, plug it where it says audio input or input or aux(auxilliary)
May 13, 2009 | RCA RS2047 Shelf System
Can't play iPod on my panasonic sa-en27 with out a remote
I ran into the same issue, instead of buying a replacement remote I was able to dial in a Vip 211 dish network remote control with remote code 643 in AUX setting. Then once the code was in, i pressed the 6 key on the remote and now I can listen to audio on the music port. The 643 code refers to the first Panasonic amplifier/receiver in the code list. To further clarify, I pressed AUX for 4 seconds, pressed 2 to signal I am programming an amplifier/receiver device, then punched in 643 then pound sign.
Good luck with yours.
Feb 14, 2009 | Panasonic (SCEN25) Shelf System
Frustrated sound won't lower
There are several complaints in FIXYA and they are all about this same fault condition....the volume is too high when turned on...
Because of the high number of complaints about this same fault I would suggest that its a manufacturer fault.
So the manufacturer should be contacted about it to ask for your money back..
Cheers From YUBEUT..
Sep 23, 2007 | GPX HM3817DT Shelf System
RCA RS2041 CD Shelf System Logo
79 people viewed this question
Top RCA Audio Shelf Systems Experts
Jaime Hernandez
Are you a RCA Audio Shelf System Expert? Answer questions, earn points and help others
