Question about Orange SPV M2000 Pocket PC
Passkey for printer
Citizen CMP-10BT, mobile thermal printer.Want to set up bluetooth to use printer. Being asked for Passkey ? Not listed in manual. HELP.
    An expert whose answer gotĀ voted for 100 times.
  • 146 Answers
Re: Passkey for printer
You can use the default passkey which is 1234..
hope this will work
all the best
Posted on Jan 31, 2008
If you do a self test, you will find the passkey on the bottom listed at the "address"'s the last 4 digits. But good luck! I have been trying for a week to get mine to connect and STAY connected AND to print! I contacted and they told me that I have to download drivers..but those haven't worked either. The tech did tell me however that the model phone I have hasn't been tested on this printer!
Posted on Jan 09, 2008
0 characters
3 Points
How to conect my hp ipaq h1940 to the computer
    • 1
      Select the "Bluetooth" icon from the Today screen of your iPAQ h1940. Click on "Bluetooth Settings." Touch the "Turn on" button.
    • 2
      Select the "Accessibility" tab from the Bluetooth menu and select "Allow other devices to connect" and "All devices." Click "OK."
    • 3
      Click on the Bluetooth icon in the upper right-hand corner of your Mac. Click "Turn Bluetooth On."
    • 4
      Select "Set up Bluetooth Device" from the Bluetooth menu and click "Continue." Select "Any Device" and click "Continue."
    • 5
      Select your iPAQ h1940 from the list of devices and click "Continue." Input the passkey number from your Mac into your iPAQ.
    • 6
      Select the type of syncs you want with your iPAQ and Mac and click "Continue."
    • 7
      Select "Browse Device" from the Bluetooth menu on your Mac and select the iPAQ from the list. Click "Browse."
    • 8
      Add or remove files from your iPAQ h1940 by clicking on them and dragging them into a file on your iPAQ or on your Mac. Close the window when you are finished and select "Turn Bluetooth off" from the Bluetooth menu.
    • 9
      Click "Turn off" on the Bluetooth icon on your iPAQ h1940.
hope it will help you..
Oct 17, 2011 | HP iPAQ H1940 Pocket PC
How do i connect a hands free kit to a htc desire
You need to put your hands free device into pairing mode this is usually done by turning the power on and keeping the power button pressed in for about 10 seconds after the power has come on. Then you should get a solid LED light up, (depends on device)
On the phone go into
1 Settings
2 Wireless and Networks
3 Bluetooth Settings
4 Turn on Bluetooth
5 Scan for devices
The name of your hands free kit should appear, select this and the phone will ask if you want to pair with the device, confirm this. You probably will get asked for a passkey or password this is usually four zeros or 1,2,3,4. enter this and confirm. Your device should now be paired and each time you want to use it just turn on your handset Bluetooth then your hands free device and your good to go.
Sep 26, 2010 | HTC Touch P3450 Smartphone
WHEN I want to pair with a using bluetooth device it asks me for a passcode for that device I have no idea what that code is. Nor Do I know what the bluetooth pass code is for my phone an LG Ku990i. Where...
Mar 18, 2010 | LG KU990 Viewty
How to open ethernet??
Task 1 - Turn on the Discoverable option on the BlackBerry smartphone Complete the following steps:
  1. On the Home screen of the BlackBerry smartphone, click Options > Bluetooth.
  2. Display the menu and click Options.
  3. Set the Discoverable field to Yes.
  4. Display the menu and click Save.
Task 2 - Pair the BlackBerry smartphone and the computer On the computer, complete the following steps:
  1. Go to Control Panel > Bluetooth Devices.
  2. Click Add.
  3. Select the My device is set up and ready to be found check box, and click Next.
  4. When the BlackBerry smartphone is detected, select the check box next to the BlackBerry smartphone, and click Next.
  5. Select the Let me choose my own passkey option.
  6. Type a passkey in the field provided, and click Next.
  7. On the BlackBerry smartphone, type the same passkey from Step 6, then click the trackball.
  8. On the computer, when the Completing the Add Bluetooth Device Wizard screen appears, click Finish.
  9. On the BlackBerry smartphone, when prompted to accept an incoming Bluetooth connection, select Don't Ask Again, and click Yes.
Task 3 - Set up the Internet access point name (APN) Note: You only need to perform this task the first time that you set up the Internet APN.
Note: If you are running Windows Vista, select Classic View.
  1. Go to Control Panel > Phone and Modem Options.
  2. Select the Modems tab.
  3. Select Standard Modem Over Bluetooth Link, and click Properties.
  4. Select the Advanced tab.
  5. In the Extra initialization commands field, type the following: AT+CGDCONT=1,"IP","<your Internet APN( for eg: aircelgprs)>"<cr>
Task 4 - Configure Dial-Up Networking Note: You only need to perform this task the first time that you configure Dial-Up Networking.
  1. Go to Start > Settings > Network Connections.
  2. Right-click Bluetooth DUN connection, and select Properties.
  3. Select the Networking tab.
  4. Select Internet Protocol (TCP/IP).
  5. Click Properties.
  6. Click Advanced.
  7. Select the General tab, and clear the Use IP Header Compression check box.
  8. Click OK to close all open windows.
  9. Go to Start > Settings > Network Connections.
  10. Double-click New Connection Wizard.
  11. Click Next.
  12. Select Connect to the Internet, and click Next.
  13. Select Set up my connection manually, and click Next.
  14. Select Connect using a dial-up modem, click Next.
  15. Select Modem - Standard Modem Over Bluetooth link, and click Next.
  16. If the Select a Device screen appears, select the Modem - Standard Modem check box, and click Next.
  17. Clear the ISP Name field blank, if necessary, and click Next.
  18. Complete the appropriate step below:
    • If the BlackBerry smartphone operates on General Packet Radio Service (GPRS) or Enhanced Data Rates for Global Evolution (EDGE) networks, type *99# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Universal Mobile Telecommunications System (UMTS) networks, type *98# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Code Division Multiple Access (CDMA) or 1x/Evolution Data Optimized (EVDO) networks, type #777 in the Phone number field, and click Next.
  19. Type the user name and password provided by your wireless service provider. If your wireless service provider has confirmed that this information is not required, leave the fields blank. Click Next.
  20. Click Finish.
Task 5 - Connect the computer to the Internet using Dial-Up Networking Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session may interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Click Start > Settings > Network Connections > <Name of the new connection>.
  2. Type the user name and password provided by your wireless service provider. If your wireless service provider does not require this information, leave the fields blank.
  3. Click Dial.
Oct 05, 2009 | RIM BlackBerry 7730
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(Do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace key.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructions.
Hope this helps. Bud
Feb 10, 2009 | LG KU990 Viewty
Can't find my Motorola H681 numeric passkey for connecting it
The default is usually 0000 on most bluetooth headsets, try to find the manual for your bluetooth device, it should say.
Jan 08, 2009 | AT&T Blackberry Curve 8300 Smartphone
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Hp 6915
what r u pairing? you need the code for what u r pairing or possibliy reqesting u to make a code up
Feb 11, 2008 | RIM BlackBerry Pearl 8100
Connect to the internet via
Once the Socketcom Bluetooth card is inserted in the Toshiba Pocket e570 PC and the software has been loaded, the following instructions will set up the Toshiba PDA & Ericsson T39 mobile phone to connect to the Internet. Click on the Bluetooth icon in the bottom right hand corner. Click on Get Connected! Select the device under My Bluetooth phone is: In this case the Ericsson T39. The following information gives details on how to change the name of the Mobile device. Once this has been read, click on Next. The phone now has to be made discoverable so that the PDA will detect it. To do this, use the down arrow on the phone to select Extras and then click on Yes. Scroll down to Bluetooth and Click on Yes. Select Make Discoverable and a message on the phone will appear saying that the phone is discoverable for the next 3 minutes. Click on Next on the PDA. The PDA will now look for a Bluetooth device(s). Once the mobile is detected the PDA will search for the Device Name of the mobile. Click on Select and the devices will not connect and create a partnership. The following Device Bonding window should appear to create a bond between the PDA and phone. Click on Next. To create the bond a passkey must be entered on the PDA. This may be a between a 4-16 digit code. N.B. We would advise that the code be kept to a numeric sequence as the keys contain more than one letter on them, i.e. for the letter L, the number 5 key will need to be depressed 3 times. Once the passkey is entered, click on the Reply button. On the mobile, click on Yes to accept the incoming pass and then enter the same passkey. Click on Yes again to confirm. If the two values are correct, a message will appear on the phone telling you that the devices are bonded. The PDA should now congratulate you on your connection. For Internet access via Bluetooth, please follow the steps outlined below. The above instructions only need to be carried out each time a connection is required. However, the instructions below only need to be setup once. Click on Start, then Settings from the drop down menu. Click on the Connections tab at the bottom of the screen followed by the Connections icon utility. In the first drop box labelled "When needed automatically connect to The Internet using these settings" select New. Under the General tab you will be prompted to give the new connection a name, e.g. Bluetooth. Select the modem "Bluetooth Phone" and click on Next Make sure that the fields for the boxes titled Country code and Area code, are empty. The next field requires the full telephone number, including STD code, you wish to dial, i.e. your ISP telephone number. Put this in and click on Next. The next page contains a time out clause if the PDA is unable to connect within a set time. By default this should be 120 seconds. Make sure the tick box for "Wait befo
Sep 07, 2005 | Toshiba e570
Orange SPV M2000 Pocket PC Logo
229 people viewed this question
Top Orange PDAs Experts
Cosma Papouis
Cosma Papouis
William Dehn
William Dehn
Are you an Orange PDA Expert? Answer questions, earn points and help others
