Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag mdg6700aww gas dryer runs but heat kicks out after 5 min
  • Maytag Master
  • 1,606 Answers
You have bad coils on your main gas valve . They tend to short (open) after getting warm which cuts off the gas to the burner . After cooling , they will work again for another 5 min until shorting again . Replace the coils (2 in a kit ).
Posted on Jul 12, 2009
Maytag Gas Dryer. Gas on. Ignighter kicks on. no heat aftrer running along time. Set idle and retried with no heat... Has ran fine for years... gas source has not been off for years... thanks
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101ooo
Aug 18, 2011 | Dryers
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
Problem with the Maytag Neptune MDG6700A Gas Dryer WHEN STARTED HEATS UP THEN NO HEAT AT ALL. MAYTAG MDG6700AWW
Hello & Welcome to FixYa
When the dryer heats for few minutes and then it won't work it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this part for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDG6700A Gas Dryer
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
No heat in gas dryer, gas good, elec good??
if the heat is on when the dryer is cold then shuts down after 15 to 30 minutes and doesn't lite for a long while you have bad gas coils,the gas should come on until it hits temp. then it shuts down,when the dryer calls for heat it will turn back on,if it stays on for short periods of time you might need to clean out the dryer,this will shut the gas down to soon,you need to clean out the duct that the lint filter slides into,blow out the vent line,make sure the air is blowing outside with nothing blocking it and vac out the inside of dryer where the motor is
Mar 12, 2010 | Maytag Dryers
Gas dry is not heating enough to dry clothes
There is two possible causes. Either your gas coils are going bad late in the cycle or your venting is restricted. I would go outside check to make sure you have good airflow. If you have good airflow outside the only common cause of gas dryers failing to heat late in the cycle would be gas coils. If you have a peep hole on your dryer look in it after your dryer has been running for approx 30 mins and see if the ignitor glows and then shuts off. If the burner does not kick on then you have bad gas coils. They are part number 5303931775.
Let me know if this helps _MJ_
Jan 29, 2010 | Maytag MDG2600BWW Gas Dryer
Gas dryer won't heat with cover off
The 2 coils on the gas valve , need to be replaced . After the dryer runs for a short time , the coils get warm from the electricity going thru them . The weaker valve , shorts internally , not letting the gas go thru . After the dryer cools down , and the coils cool down , then the short will close ( giving continuity ) , until they warm up again . If you had given the model number , I would have given you the part number .
Sep 17, 2009 | Maytag Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Maytag performa dryer won't run right
bad motor,,should have change it when you had it open,,thats the overload you hearn inside the motor,,when hot it clicks off and when itcool it will run a while than click off...again...need help changing ..
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
470 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
