Question about Garden
I have aryobi 15" electric weedeater; it's been sitting around for a while, and now I am unable to remove the retaining cap to add line. I've tried wd-40, various wrenches, etc. I have the manual but it is no help, simply tells you to remove the retaining cap by rotating counter-clockwise. Any suggestions before I find a repair shop? sheila
  • srbphd Jul 12, 2009
    it isn't moving at all, even with a monkey wrench; i'll try and find a way to apply more pressure and let you know what happens.
    sheila
  • 3,037 Answers
You have tried a monkey wrench on it? Have you gotten it to turn at all? Or is it turning and not unscrewing as you may have to hold the shaft in place if you haven't been doing this. It gets torqued on really tight from the spinning so just use a little more force on it.
Benjamin
Posted on Jul 12, 2009
  • Benjamin Patri
    Benjamin Patri Jul 12, 2009
    ok, maybe a quick tug or hit on the wrench is need to **** it loose
Need parts for American Gardner Yardstick model YS24. Specificly the line head assembly.
How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
Sep 01, 2013 | Weedeater Garden
Removed gas tank guard now won't start
Overtime, Jeep Grand Cherokee fuel tanks develop rust and accumulate sediment. This is especially true if the tank sits empty for a period of time. Rust and sediment can break loose and cause clogged filters. When the filter is clogged, the engine does not receive the amount of fuel required to operate. The fuel tank can be cleaned out; however, replacing the tank is easier.
  • 1 Apply the parking brake.
  • 2 Remove the gas cap.
  • 3 Remove the fuel pump relay from the power distribution center under the hood. Look at the underside of the power distribution cover, and locate the fuel pump relay.
  • 4 Attempt to start the engine, cranking the engine for several seconds.
  • 5 Turn the ignition to "Off." Install the fuel pump relay.
  • 6 Disconnect the negative cable from the battery.
  • 7 Lift the fuel tank into position, using the jack.
    8 Attach the fuel filler hose and vapor return hose to the fuel tank.Tighten the clamps with a Phillips screwdriver.
  • 9 Pivot the fuel tank retaining straps into position. Tighten the fuel tank retaining strap nuts with a socket and ratchet. Lower the jack.
  • 10 Connect the fuel pump electrical connector, the fuel filter line and the fuel return line. Push the fuel line retainer into the chassis.
  • 11 Raise the heat shield. Install the mounting bolts. Tighten the mounting bolts with a socket and ratchet.
  • 12 Install the tow hooks or trailer hitch, if equipped.
  • 13 Lift the skid plate into position with the jack. Tighten the skid plate mounting bolts with a socket and ratchet.
  • 14 Attach the electrical service connector to the bumper with a socket and ratchet.
  • 15 Raise the jack and remove the jack stands. Slowly, lower the vehicle.
  • 16 Pour the fuel into the gas tank. Connect the negative battery cable.
  • Buy Custom car Parts.
    Jun 02, 2012 | 1995 Jeep Grand Cherokee
    How to remove the trimmer wheel to add more wire?
    In order to add more wire, remove trimmer head by removing center main screw. The whole cap will come off with a little of force towards the outside. Then you will put the string inside the channels dedicated to do this.
    Thanks
    Jul 25, 2011 | Poulan Weedeater/Electric Trimmer 4.1 Amp
    The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
    The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
    Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    I have a 96 Ford Countour that has starting problems. In the morning it will start, then after driving for awhile, parking it, then trying to start again, it won't. It is worse on warmer days (it...
    It will start when cold, and after driving and then parking, the starter will not turn over? Replace your starter/solenoid.
    WARNING: WHEN SERVICING THE STARTER MOTOR (11002) OR PERFORMING OTHER ENGINE COMPARTMENT WORK NEAR THE STARTER MOTOR (11001) , BE AWARE THAT THE HEAVY GAUGE BATTERY INPUT LEAD AT THE STARTER SOLENOID (11390) IS "ELECTRICALLY HOT" AT ALL TIMES. BE SURE TO DISCONNECT BATTERY GROUND CABLE (14301) BEFORE SERVICING STARTER MOTOR .
    2.0L Engine Starter Removal
    1. Disconnect battery ground cable.
    2. Remove engine intake air resonator and air box.
    3. Disconnect the intake air temperature (IAT) sensor and mass air flow (MAF) sensor.
    4. Remove three starter motor retaining bolts and ground wire.
    5. Raise vehicle on hoist.
    6. Remove integral connector retaining nuts and wires from starter solenoid.
    7. Disconnect the knock sensor.
    8. Remove the axle shaft bearing bracket bolts and position the bracket aside.
    9. Remove the starter motor.
    Installation
    NOTE: When installing lower starter motor retaining bolts, be sure to install ground cable.
    1. Position starter motor to transaxle and loosely install lower retaining bolt.
    2. Install axle shaft bearing bracket. Tighten to 21 Nm (15 lb-ft).
    3. Connect knock sensor.
    4. Install integral connector retaining nuts. Tighten B-terminal retaining nut to 11 Nm (97 lb-in). Tighten S-terminal retaining nut to 5 Nm (44 lb-in).
    5. Lower vehicle to floor.
    6. Install starter motor retaining bolts and ground wire. Tighten to 20 Nm (15 lb-ft).
    7. Install engine intake air resonator and air box.
    8. Connect the IAT and MAF.
    9. Connect battery ground cable.
    2.5L Engine Starter Removal
    1. Disconnect the negative battery cable.
    2. Disconnect the idle air control (IAC) valve hose from the intake manifold.
    3. Remove the IAC valve hose locator from the upper radiator hose.
    4. Remove the positive crankcase ventilation (PCV) hoses from the air cleanter outlet tube.
    5. Disconnect the intake air temperature (IAT) and mass air flow (MAF) sensor electrical connectors.
    6. Disconnect the air cleaner inlet tube from the air cleaner housing and the outlet tube from the throttle body.
    7. Remove the air cleaner assembly.
    8. Remove the air cleaner housing support bracket.
    9. CAUTION: Do not carry an open flame of any type when working on or near an open fuel system. The fuel system remains under pressure for long periods of time after engine shutdown. The fuel pressure must be relieved before performing any service to the fuel system.
    10. Remove the protective service valve cap and connect the Multiport Fuel Injection (MFI) Fuel Pressure Gauge T80L-9974-B to the fuel pressure service valve, located on the fuel injector rail. Slowly open the valve and relieve the fuel system pressure. Remove the gauge and install the protective service valve cap.
    11. Remove the safety clips and disconnect the fuel line couplings using disconnect tools D87L-9280-A (for 3/8-inch lines) and D87L-9280-B (for 1/2 inch lines). Install protective caps and position the fuel lines out of the way.
    12. Remove the transaxle selector cable bracket retaining bolts and position the bracket (with cable attached) aside.
    13. Disconnect the starter motor solenoid electrical connectors. Secure the battery cable harness and the heater hoses aside.
    14. If equipped, remove the starter motor support bracket.
    15. Remove the starter motor.
    Installation
    1. Install the starter motor. Tighten the bolts to 25 Nm (18 lb-ft).
    2. If equipped, install the starter motor support bracket. Tighten the retaining bolt to 25 Nm (18 lb-ft). Tighten the retaining nuts to 17 Nm (13 lb-ft).
    3. Connect the positive battery cable and solenoid harness to the starter motor solenoid. Tighten the battery cable retaining nut to 12 Nm (9 lb-ft). Tighten the solenoid terminal retaining nut to 5 Nm (44 lb-in).
    4. Install the transaxle selector cable bracket. Tighten the bolts to 20 Nm (15 lb-in).
    5. NOTE: Inspect all O-ring seals and garter springs for damage, prior to assembly. If either O-ring is damaged, both O-rings must be replaced. Replace the O-rings or garter springs only with the appropriate replacement parts. Lubricate the O-rings with clean engine oil, prior to assembly.
    6. Remove the protective caps and connect the fuel line couplings. Install the safety clips.
    7. Install the air cleaner housing support bracket. Tighten the bolts to 25 Nm (18 lb-ft).
    8. Connect the air cleaner housing to the air cleaner inlet tube and the outlet tube to the throttle body. Install the PCV hoses to the air cleaner outlet tube. Connect the IAC valve hose to the intake manifold and securely tighten the retaining clamp. Install the IAC valve hose locator to the upper radiator hose. Connect the IAT and MAF sensor electrical connectors.
    9. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
    10. Connect the negative battery cable.
    I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
    May 18, 2011 | 1997 Ford Contour
    How to replae the ignition coil in a 93 corvette
    REMOVAL & INSTALLATION
    2. Remove the intake manifold plenum extension.
    3. Tag and disconnect the secondary wires, then remove the retainer(s) from the distributor cap, and position aside.
    4. Unfasten the 2 coil cover attaching screws, then lift the cover off.
    5. Remove the 4 coil-to-cap attaching screws and lift the ignition coil and leads from the cap. Fig. 1: The ignition coil is secured to the distributor cap with 4 screws 91032g04.gif
      Fig. 2: View of the ignition coil removed from the distributor cap 91032g05.gif
    6. Remove the ignition coil arc seal.
    7. Clean the cap with a soft cloth and inspect for defects. Replace if necessary. To install:
    8. Place a new seal on the distributor cap.
    9. Position the ignition coil to the distributor cap and secure with the retaining screws. Tighten the screws to 13 inch lbs. (1.5 Nm).
    10. Attach the coil electrical leads.
    11. Install the distributor cap cover.
    12. Attach the secondary wires, as tagged during removal and install the retainer(s).
    13. Install the intake manifold plenum extension.
    14. Connect the negative battery cable.
    Aug 18, 2010 | 1993 Chevrolet Corvette
    How to remove fuel pump on Neon 1998 ? can I reach from inside the vehicle ?
    on a dodge neon the fuel pump is in the SIDE of the tank... NOT the top. to remove the pump follow these steps...
    ******* first unplug battery and remove ********
    1. unbolt passenger side tank strap and lower side of tank.
    2. a. if tank is plastic, CAREFULLY unscrew plastic retainer ring but do NOT remove.
    b. if metal tank, unscrew metal retainer flange but do NOT remove
    3. unplug electrical connector and fuel line from pump. move aside.
    4. completely remove retainer BE CAREFUL not to disturb pump.
    5. have drain pan or wide-shallow bucket available to collect gas. (if tank is full this will need to be able to hold 7-8 gallons)
    6. gently twist and pull pump out till gas comes fourth. catch gas in pan/bucket.
    7. remove pump when gas stops flowing.
    8. install is reverse of removal.
    9 BE CAREFUL not to wrinkle gasket or lose gasket into tank when installing or the tank will leak around pump.
    10. tighten retainer but DO NOT OVER TIGHTEN.
    11. reconnect plug and fuel lines check for leaks.
    12. reattach tank strap and fasten
    13. refill tank with clean gas. check for leaks.
    14. put battery back in. connect battery, start your neon and check for leaks one last time.
    15, have fun. this will take about 4hrs to do by yourself with proper tools.
    Apr 24, 2010 | 1998 Dodge Neon
    Weedeater quits working/button no longer activates weedeater
    try this get a good extension cord test it plug it in now with the trigger pulled wiggle the cord going into the weeder i have in the past moved the cord till i got working and taped it to the handle, if that dosent work get a new one
    Mar 07, 2009 | Poulan Genuine Weedeater Part # 36006-128
    Garden Logo
    35 people viewed this question
    Top Garden Experts
    roeb
    john h
    Marvin
    Marvin
