Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Engine pumps raw gas out of the carb under power
When my engine is running idles fine but give it throtle and it pumps raw gas up out of the carb then floods out
  • 5 Answers
NEED TO KNOW WHAT KIND OF ENGINE. DOES IT HAVE A PUMP? IS IT GRAVITY FEED? IS THE CARB AND GAS TANK ONE PIECE? IT SOUNDS LIKE FLOAT IS STUCK OR FLOAT BOWL GASKET BAD. COULD BE ALOT OF THINGS. NEED ENGINE MODEL OR NAME ON COVER.
Posted on Jan 06, 2010
Carb has gas and will idle but won't run when you give it gas
You might want to explore rebuiding the carb. Sounds like you have either a bad power valve or power valve diaphram or a totally worn out accelerator pump OR a combination of faults. It's an '84 chances are the carb has not been warmed over, this would be a good $45 INVESTMENT IN A FINE OL TRUCK and a fine ol motor.
Apr 03, 2011 | 1984 Dodge D150
Drz 400 sm starts but i cant give it any gas or it dies
Can you slowly increase the revs? It sounds like an accelerator pump or debris in the carb.
Jul 09, 2009 | 2007 Suzuki DR-Z 400 SM
Bike starts fine and idles, when i twist the throtle it stalls
does this happen all the time or just sometimes?if it happens all the time you need t change your spark plug sometimes you probally have water in the gas drain the carb bowl the little flat head brass screw on the bottom of the bowl make sure your gas is on to flush it out buy some stabil ethonal treatment and run it every tank fuel good luck
Jun 25, 2009 | 2001 kawasaki KLR 650
I have a 2000 hyuandai Sonata 2.4 16V engine won't run
Remove air intake from throtle housing.Spray carb cleaner in and around the butterfy.Leave to evaperate then replace the air intake pipe and start.
Jun 13, 2009 | 2000 Hyundai Sonata
My 1986 Ranger 2.9 liter is hard to start (i have to pump the gas to get it to start) once it starts it runs fine until it gets warmed up then when you step on the gas it falls flat no power will not move,...
Just taking a shot here as I have seen the same thing in the shop in that last month....I am going to throw you two scenarios as you don't say if it has a carb or F.I.
If it is Fuel Injection the filter or a weak pump would be the culprit.
If it is a carb engine there is an item called an accelerator pump. this pump pumps fuel into the throat unmixed so during startup and on acceleration it needs this raw fuel, on startup to just get fuel into the chambers and on acceleration when switching from the Idle to the venturi there is a dead spot that this pump covers for.. A 20 dollar rebuild kit for the carb is all you need. there should be a tag on the carb for the ID to give to the parts store..
Mar 08, 2009 | 1986 Ford Ranger 2WD
Huskvarna model 141le wants to run full throtle all time
Hi
Adjust H,L and T from the carb.When the engine is warm check the spark from the sparkplug:It has to be a strong violet spark(not flame).Disassembly the carb and carefully clean it.Check the fuel pump(it should be tighten not bended),Check the fuel filter and air filter.;the gas tank ventil and the fuel hose.
regards savumihai71
Dec 04, 2008 | Husqvarna Chain Saw 20" Bar
Rough idle at low rpm
just cleaned top half of carb, the venturi was dripping raw gas into the carb, running rich and stalling.
cleaned bowl and compressed air blow out parts and runs better now.
but know introduced new problme where it runs rough when you give it gas, not reving upp. now.....
Oct 24, 2008 | 1989 Jeep Wrangler
Sears 4000W 8HP doesn't idle up under load
I posted an answer to a similar question here. You probably have a broken current transformer or a bad idle control board.
Rate me?
Oct 22, 2008 | Electrical Supplies
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
420 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Randy Schumann
Randy Schumann
Tom Chichester
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
