Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Fridg. will only get cold at highest setting why
  • 53 Answers
Could be due to only two reasons:
1) Please check your thermostat and in case it is defective get it replaced to solve this problem.
2) The refrigerant is leaked and it needs rectification. Flushing out the dirt and then recharging of refrigerant. This will solve your problem immediately.
Posted on Jul 12, 2009
I have a mini fridge from chef mate that does not have a freezer in it. It won't keep temp cold even though it's on highest cold setting. Any answers?
in a fridge the highest or coldest setting is 1 or 0
the bigger the number the warmer the setting
door seal /door not closing properly
have a technician check out the thermostat for correct operation
Dec 10, 2016 | Refrigerators
Uline wine fridge 2075-wcs not cold enough
Check condenser make sure it is clean then listen to see if condenser fan motor is running . if compressor is running cuntinuesly and other mentioned are ok it could be low on Freon
Nov 08, 2012 | U-Line Refrigerators
My freezer wasn't defrosting and the fridge wasn't as cold as it should be. I emptied it out and unplugged the fridge for 2 days and plugged it back in. Settings for freezer and fridge are on the highest...
hi how are you...please turn down setting to original setting from factory...in the freezer,does the back panel have ice on it....if so you have defrost problm...if not remove panel...if one one place on coil has ice ,but not whole coil...then has a freon problm....allow 24 hours for settings to readjust....hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...call if need assistance...good luck...
Mar 26, 2010 | Maytag MTB1956G Top Freezer Refrigerator
Refrigerator warm, and freezer cold?
The fan in the freezer is not blowing the cold air into the fridge through the damper or more likely the damper isn't open. It's controlled by the fridge temp control knob. If it's an electronic control then it's probably bad. If it's just a mechanical knob then the linkage connecting it to the damper may be disconnected.
Jan 30, 2010 | Refrigerators
Fridge freezer HNMF2805-80. fridge is freezing
isnt that the highest you could put it. how about taking it down to 1 or 2. it should say on the nob.
Jan 28, 2010 | Hoover Refrigerators
Refridgator too cold and on highest setting
i'm guessing your fridge is over - packed with alot of food - i found if i made more space - temperature returned to normal cooling.
hope this helps
marneypants
Oct 02, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Kg34na90gb fridge freezer - fridge temperature cold, no matter what the setting on door control. Fresh food suffers as a result of almost freezing conditions.
turn the freezer up to highest setting and set the refrigerator control to about half way. this will block some of the airflow into the refrigerator.
Jul 06, 2008 | Siemens Refrigerators
Refrigerators Logo
71 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
