Question about Fisher and Paykel DEGX1 Electric Dryer
Wont heat cant get the dryer to heat have cleaned out lint tray
  • bigboyj Dec 09, 2007
    i replaced the heating element about 2 hours ago and it wont heat but the heating element lights but i don't know
I know you possibly have checked this, but have you tried dismantling the fan to see if its full of debis, and dust?preventing it from turning freely.
Posted on Feb 02, 2008
The sensor may need to be reset. My felt filter had come off but the dryer worked fine until everything filled with lint. Much of the lint was in places you can't get to easily and Fisher Pykel doesn't mention cleaning these areas in their manuals. I know it is to late to help you but it may help someone in the future.
Posted on Jan 07, 2008
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
Dec 12, 2013 | Bosch Nexxt 500 Dryer
Whirlpool gas dryer WGD5540SQ it is getting power, drum does not turn, just hums when I push start button. I checked for blown circuit breaker, i' ve cleaned lint tray and checked vent to outside. I've...
there is a reset button on the motor more then likely it tripped, there are actually two one resets the other trips, but here is a website it will help with the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Whirlpool WED5520SQ Gas Dryer
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
Dryer won't start
remove filter then try or with filter out look in side if dirty go to lowes get a lint brush
Apr 21, 2010 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
I have a kenmore 76712. clothes only gets warm but does not dry even after 3 cycles. I have looked in the back cabinet and i see the ignition working and lighting up. But it goes off after about 5-8 secs...
The unit must be taken apart to clean. Also the duct work (vent tube) will have to come completely apart for those tubes will be solid full of lint as well. That is why the dryer is not drying your clothes. I guarantee you will find a handfull of lint for every foot of tubing you have. OInce cleaned the dryer will operate like new again
Apr 21, 2010 | Dryers
Clothes dryer produces black soot when drying and leaves clothes darkened
lint build up is on heat element canister. take dryer apart on clean with a good vacumm cleaner. unplug first.
Mar 02, 2010 | Dryers
Lint not catching in tray and is clogging the roof vent
This is common on all dryers. Not lint screen will catch all the lint although some are better than others. If you haven't already, you will need to clean or have your home vent cleaned (with a brush that goes all the way through the vent). If vent is not cleaned the lint will back up all the way into your dryer and cause a mess. You have stated your vent goes up to your roof so you will need to clean it every 6mths to 1yr. Aside from this there is no fix that I am aware of. Please rate me after reading this.
Dec 14, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Fisher and Paykel DEGX1 Electric Dryer Logo
113 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
