Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Exxcel Type S9N61B
Water does not appear to be heating
Element seems ok
There is no power going to the element when it should during the operation
    Sergeant:
  • 228 Answers
IF YOUR DISHWASHER IS OVER 3 YEARS OLD IT HAS PROBABLY BLOWN THE HEATER IF THEY ARE USED ON REPEATEDLY LOW TEMP WASHES FAT CAN BUILD UP AND DESTROY THE ELEMENT ON A 35 QUICK WASH IT SHOULD HEAT UP WITHIN 12 MINS OF STARTING IF NOT HEATING APPLIANCE WILL WASH FOR UP TO 3 HOURS IN COLD WATER IF CYCLE TIMES ARE NORMAL BUT NO HEAT IS EITHER A THERMOSTAT OR PCB FAULT THE FORMER IS LESS LIKELY,YOU SHOULD GET AREADING OF AROUND 25 TO 30 OHMS ACROSS LIVE AND NEUTRAL AND INFINITY ACROSS LIVE TO EARTH AND NEUTRAL TO EARTH.
HOPE THIS HELPS
Posted on Aug 01, 2009
I got bosch exxcel watching matchine it is not heating up the water the element is fine but matchine is not hating up the water .
It must have a thermostat to prevent the water from getting too hot. The thermostat sensor/switch is stuck in the " off " position. The only other thing it could be is the temp boost switch is defective. Just because the heating element looks good, does not mean that it is good.
Jun 03, 2014 | Dishwashers
I have a Bosch exxcel 1600 express washing machine which has packed up heating the water i have checked the heater element and i have signal in and out of element so ok also checked wiring up to control...
This appears to be the vacuum pipe that detects when the drum has sufficient water levels, have you checked the temperature sensor is activating.
Jul 31, 2013 | Washing Machines
Bosch exxcel washing machine not heating water
Are you sure it's not heating the water? The only time it heats is when it takes the detergent, all rinses are in cold water only. To test the heater, put the dial to the OFF position, press and hold the start button whilst turning the dial one click to left (30 easycare) when the two middle lights come on or 888 in display (if there's a display), take your finger off the start, turn the dial to 90 cotton (the long way, counterclockwise, not thro the OFF) press start, the tub will fill and it will do a stationary heat, you should hear the element/water making a noise like a kettle boiling. Leave the machine like this for a few minutes. Put dial to off until the door lock disengages and touch the water to see if it's warm. Put the machine on drain to clear water. If there is defo no heat repost and I will give you step by step of changing element.
Cheers Roni
Mar 01, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch exxcel dishwasher SGS43EO2 not heating water.r
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 20, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
My dishwasher dont dry
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 18, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Not draining water and not cleaning all, pipes ok is machine just old bosch exxcel dishwasher
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
e
Dec 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Fitting a heating element to a Kenwood dishwasher
E3 usually means the heater element has failed. From the title of tyhe post it seems you know that already.
Jun 27, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water is not going into the machine - and yes the water is on
There is a heating element in the dishwasher that heats the water to about 155F at which point a thermostat closes and sends power to the timer to advance. If the water does not reach this temp, the dishwasher will not advance. Often the problem lies in a faulty part in the heating circuit like the heating element or the thermostat but you will need a technician to verify.
http://tclaundryrepair.com/
Feb 20, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Bosh exxcel dishwasher heater problem
Check with multi-meter for power on the heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Sep 09, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
199 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
