My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few times. No picture comes on and there is no sound. HELP ME! btw....I replaced the lamp four months ago... See less
  • 304 Answers
Chances are that the Interlock Safety Switch is not properly set. Remove the Lamp Door and then reinstall the door and tighten the screw. This will reset the Switch. If that does not fix the problem make sure that the Lamp is correctly seated. Beyond that you will need a trained samsung tech troubleshoot the set because it can be a bad Lamp Ballast,DMD bd,Main bd,Color Wheel. Also make sure you have the correct lamp. There is a Lamp Code sticker on the left side of the set. Match the code from the tv to the new lamp you purchased.
Posted on Jul 16, 2009
2 Suggested Answers
praky16
  • 744 Answers
SOURCE: my samsung dlp has no picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 12, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
My samsung 50 dlp tv has stopped working it will come on for 2 minutes i will get a picture and then i lose the picture i still get the sound but the tv goes black what is the problem there are three...
on dlp units there's a bulb that needs to be changed
avery 2-4 yrs..try and do that first..if that wont solve the problem..then try the color wheel if u here a humming noise before it shuts down.
any questions--->bhzrdg@yahoo.com
Jan 24, 2010 | Samsung Remote Control
Samsung dlp hls6186w, picture has darkened, could it be the lamp or is it the colour wheel??... tv is making sounds...I thought it was the fan, the fan looks okay??? It also shuts down once and a while...
The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Samsung HLS6186W 61 in. Plasma HDTV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
