Question about Hotpoint Ariston NWXR483EGWW Electric Dryer
Timer appears to not be working, no clicking noise as I turn it, and the dryer will no longer turn on no matter the setting
  • brianmackeil Jul 12, 2009
    Thanks, but it appears to be only the timer knob that has failed. After disassembling, I detected cracks on the inside of the knob along where it meets the stem. I turned the pin with pliers and it appears to be working. So I will try replacing just the knob if I can find it. The dryer is less than five years old. I can replace the timer mechanism if need be, however I think because of the age of the dryer, I will try to replace just the knob first.
  • 6,784 Answers
HI, this absent clicking noise from the timer control is a signal of a failed timer mechanism. replace this damaged timer asap, if possible. it has failed.
Posted on Jul 12, 2009
Dryer working fine. Then go to use it and nothing. does not turn on. No noise. No thrown breaker. a little bit of noise(clicking) from dial (timer) when turned on. On some settings but not all.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Whirlpool LER5644J Electric Dryer
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 series
positon sensor or timer issue replace
Mar 09, 2010 | Kenmore 63942 Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore dryer stop working after a lightening storm. checked breakers appears ok, but when you push start switch after setting timer i hear humming noise coming from timer but dryer will not come on.
It is very possible the humming is not comming from the timer, but the motor. check the capacitor on the motor. it should be a 5 or 8 microfarad cap .replace it. Dont try and run motor like that anymore untill it is checked.
Sep 24, 2009 | Dryers
Will not turn off
The clock motor in the timer may have debris in it's internal gearing or the timer mating gear to the motor can be damaged or have debris in it's teeth at the point of stoppage. Replacing the timer is the usual and quick fix.
Aug 08, 2009 | Dryers
My dyer is not heating all of the time no matter what setting I use. I had 2 rollers replaced because they appeared to be rubbinbg and making a noise. The dryer is still not heating and drying the clothes
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Hotpoint Ariston NWXR483EGWW Electric Dryer Logo
116 people viewed this question
Top Hotpoint Dryers Experts
shaun taylor
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
