Question about Fisher and Paykel GWL11 Top Load Washer
Need to replace drain hose
We have a fisher & Paykel ecosmart GWL11 washing machine. Our cat unfortuately placed a couple of holes in the external drain hose and we need to replace it. I have contacted Fisher and Paykel and have priced out a replacement, however I can't figure out how to remove the clip and drain hose to replace it. Any suggestions?
  • 1 more comment
  • Anonymous Apr 02, 2008
    Our cat got behind the washer and was trying to get out . He clawed his way out with a few holes in the hose, We got a hold of the company we bought it from and they said we would have to buy the wiring and hose at a price of $65.00 dollars. That is a little much for us .We have it cobble up and is working, we cut some of the hose off and added another hose. But we may have a small leak. Please advice of this matter if possible. we live in the USA in Oregon. Thank You
  • Anonymous Mar 15, 2014
    Our fisher and paykel is nto draining how can we fix it
  • Anonymous Mar 31, 2014
    I've turned the washer I=on its side and can see the bottom of the rotor. Cant figure out how to remove the cover to replace the rotor.
  • 351 Answers
There is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
Posted on Mar 09, 2008
Diverter getting constant power on fisher & paykel ecosmart washing machine
I think this is a motor controller fault causing the pump to run constantly. replace the motor controller.
Aug 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Ecosmart WA37t26gw2 won't drain
Check your belts and replace if faulty
turn the pump by hand with belt off to see if pump is jammed
still no go, you may have a faulty electronics board.
Oct 30, 2011 | Fisher and Paykel GWL11 Top Load Washer
My ecosmart GWL11 Fisher and Paykel washing machine is leaking water from the bottom, I think during the spin cycle, but am not sure--there is a puddle of water when I come out to put clothes in dryer. ...
Double check your drain hose is both attached and that there are no splits in the hose. I have found that even the smallest split/hole leaks huge amounts of water. If the hose has come off you will obviously need to reattach it, if it is split i found it best to replace rather than repair the hose.
Oct 25, 2010 | Washing Machines
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer leaking from top
Sounds like it's plugged and the water is thrown by the centrifugal force. Sometimes stuff can get between the drum and tub, plugging the drain. This can be sporadic, sometimes no problem cuz the item is away from the drain hole during extract.
Sometimes minor partial disassembly will allow you to see between the drum and tub. A pick up tool can snag things down deep.
Jan 24, 2009 | Fisher Paykel EcoSmart GWL15
Washing machine faulty
needs a new pump and control maybe, its the most common sollution for that problem
Jan 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Changing the drain hose
Nov 29, 2006 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
607 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
