Question about Grilling
How to install new burners in Charmglow 720-0230 Gas Grill Bought at Home Depot
  • 36 Answers
SOURCE: clogged gas line new grill-
Check a few things:
Make sure your hose is not chewed or marred.
Make sure you are turning the unit on and off correctly. Webers are different than other grills to turn on /off. Please check your manual for the instructions on how to do this.
Another thing if this is propane it might be a spider in your grill that is clogging the unit for you.
go to: weber website they will be able to help you.
Posted on Apr 26, 2008
SOURCE: gas grill ignitors
I recently moved. When the grill arrived to the new home I had to purchase a new propane tank to replace the old one. The grill will not light. For some reason it isn't getting any gas. Any suggestions on what the problem might be?
I tried the obvious... tightening the connections, trying to light it manually etc.
Thanks,
K
Posted on Jul 13, 2008
SOURCE: burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Posted on Oct 26, 2008
SOURCE: having trouble changing 3 steel pipe burners on Charmglow grill
The best way to install these burners is to get a vice grip/pliers and bend the end of the burner where the screws can be placed. If you notice on that end there appears to be a section where it will bend without impacting the integrity of the burner itself. It will bend enough for you to place the burner in its place. Once installed, bend back and screw in the screws to hold in place.
Posted on Feb 26, 2010
  • 3411 Answers
SOURCE: We have a Charmglow 720-0234 5 burner gas grill.
i would drill them out and replace with new
Posted on May 16, 2010
I just purchased a pre-assembled E-310 Weber gas grill from Home Depot. Upon Start up I noticed the flame is very high on each burner (three to 5 inches above the deflectors on high). Also, I notice n
Hey Anon..
WOA...compressed propane is not something to mess around with..I would go back to the Home Depot and talk to the store manager,,(take your receipt and all other paper work for proof), ask him who to see about your issue.. tell him you are afraid to use your NEW grill.(Start at the top!).. you spent good $$$$ and you deserve an answer..or a new grill..
Sep 11, 2017 | Weber Genesis E-310 Gas Grill
I am trying to install the grease tray on me grill. I had Home Depot put it together. I can't find the tracks to slide it in on. Seems kind of basic, but I'm not getting it. I'm sure...
Cy, Home Depot must have given you a good deal on this model, as it has been discontinued by Brinkmann. Never the less, Brinkmann still supports it.
In case Home Depot failed to include the Owner's Manual when they delivered it. I have included a link to it, that you can download & print for future reference. Starting on Page # 20, you will see how to install the drip pan.
http://images.brinkmann.net/docs/pdf/810-6805-1.pdf
I hope this helps you and thanks for choosing FixYa.
Aug 21, 2011 | Brinkmann Charmglow Stainless Steel LP...
Searching for an owners manual for my grill
In my online research, I was not able to find any free downloads for manuals of this brand. I did find a website that sold Charmglow manuals, though they did not list your specific model. However, they have a toll free # you can call and request your specific model manual. Hope this helps.
http://www.appliancefactoryparts.com/gasgrillparts/brands/charmglow/charmglow-manuals.html
May 16, 2010 | Home Decorators Collection Charmglow...
3 burner charmglow gas gril
I am replacing burners and I need to know if the burners if they go tightened or loose.
Oct 20, 2009 | Brinkmann Charmglow Stainless Steel LP...
Push button igniter appeared to be missing parts when I purchased the grill new from Home Depot last month. I called Charmglow and they finally sent me a new igniter and it won't work, does nothing. Help!
did you put a new battery in, if won't work turn the battery around the other way and see if it works if not call back charmglow and ask them to send a new one to you.
Oct 17, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Reviews
If you have not had it for the full warranty period, by all means. (I would call their Customer Service number first.) Here is the site for phone numbers:
Home Depot Contacts
You might also be interested in this website. You might use this for "ammunition".
http://www.consumeraffairs.com/homeowners/charmglow.html
Apr 11, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Regulator freezing up
1. Are you using a portable LP cylinder? LP Regulators freeze up when the liquid part is the propane is flowing through the regulator this is caused by an overfilling of the propane tank.
2. If the BTU capacity of the regulator is not high enough to cover the BTUs of your grill, the regulator is working too hard and potentially pulling liquid (not vapor as it should)
I would suggest calculating the BTUs of your grill and looking to see what the capacity of the regulator you are using.
You can also read this about regulators LP Gas Regulators 101
Nov 13, 2017 | Brinkmann Charmglow 810-7400-S Propane...
Gas grill ignitors
Check the electrode.  That is the end at the burner.  It may be corroded and no longer creating a spark.
Jun 05, 2008 | Weber Q300 Grill
Grilling Logo
678 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
