2001 honda elite 80cc
LOOK FOR AN INSPECTION COVER ON THE LH SIDE OF ENGINE, REMOVE COVER, ON TOP OF CYLINDER THERE SHOULD BE ANOTHER COVER, ALSO REMOVE. REMOVE SPARK PLUG, USE A THIS SCREW DRIVER, PUT IT INTO THE SPARK PLUG HOLE CAREFULLY ROTATE THE ROTOR IN THE DIRECTION OF ENGINE ROTATION WATCH FOR THE SCREW DRIVER TO SLOWLY COME OUT OF THE CYLINDER IT WIIL RISE AND THEN FALL, AT THE PIONT OF DIRECTION CHANGE THIS IS TDC, REVERSE IT TO TDC, SEE IF YOU CAN SEE INTO THE INSPECTION HOLE THERE SHOULD BE A LINE AND A SMALL NOTCH ON THE SIDE OF THE HOLE. NOW LOOK AT THE TOP OF THE ENGINE WERE YOU REMOVED THE SECOND COVER THE CAM SPROCKET WILL HAVE A DOT ON IT, THIS SHOULD BE POINTED TO THE TOP. THIS IS IN TIME. AGIAN, PISTON AT TDC, ROTOR FIRE MARK LINED UP WITH NOTCH IN INSPECTION HOLE, CAM SPROCKET DOT POINTED TO TOP OF CAM COVER, YOU MAY HAVE TO MAKE ONE MORE ROTATION TO GET ALL MARKS TO LINE UP AT THE SAME TIME. IF YOU HAVE REMOVED THE CAM YOU MAY HAVE TO WALK THE CHAIN AROUND THE SPROCKET TO GET IT INTO TIME, ALSO TAKE ANY DEFLECTION OUT OF CAM CHAIN.
