Question about Saeco Royal Professional Espresso Machine
Saeco royal proessional does not get power when i turn on machine
My saeco royal prfoessional does not get power when i turn the on switch. the circuit has power for the toaster and other applicances
does this machine have a fuse . there is no lights on the display panel
You can check the fuses on the power board..there are 3 pcs of fuse ..check the microswitch on the side door,waste container and the brewing unit...it may solve your problem.
Posted on Aug 17, 2009
  • 1,089 Answers
HI
The machine has a couple of fuses. They are all special fuses and not easy to find. There is 1 inside the machine under a cover by the pump. It is a special 8 Amp. There is an other one on the back side of the power board This one is a T.35ma.
Posted on Jul 14, 2009
My Saeco Royal coffee machine is displaying 'empty water container' and it is full - what is the problem
Is the floating magnet in the water reservoir floating ? If yes, you will have to check:
1) the micro switch which is located just beside the magnet (open the machine to check it with and ohm-meter) Check it with a small magnet that you have
2) if the micro-switch is OK with a hand-held magnet the floating magnet may be de-magnetized
3) if everything above is OK, the input on the control board is perhaps defective
Mar 23, 2012 | Saeco Royal Cappuccino Espresso Machine
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
My saeco royal professional has no power, no lights. What's up?
Hi
First I would check the switch on the bottom left side of the machine and make sure that it has not been turned off.
If it is on you may have a fuse out on the board. It is a very special fuse. It is a 35Ma timed lag fuse When we change them we put in a 50Ma Timed lag fuse with no problems, because the 35MaT is hard to find.
May 05, 2010 | Saeco Royal Professional Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
Where is the fuse on a saeco royal professional unit? i lost all the power on my espresso machine and i'm assuming the fuse is the problem but i cannot seem to locate it on the unit itself?
There is a special *amp fuse inside on the back bottom of the machine. It is next to the pump. There is a gray cover over the power filter where the fuse is ;located. You can see the power wires going into the cover. There is also a special .35maT fuse that is on the back of the power board.
Feb 12, 2010 | Saeco Royal Professional Espresso Machine
No power -- where is fuse?
Fuse is inside the machine. Looks like a black wire thats fat in the middle.
Its either that or the main board blew. I pray it is the fuse because saeco doesn't sell the royal boards anymore from what i understand.
May 26, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal not powering up
you can remove what you whant but i just finish repairing one that was not powering up it was just the plug that goes in the wall i know you post that long time ago and machine probably repair by now cheers
Dec 26, 2007 | Saeco Royal Professional Espresso Machine
No power to unit
If you had a leaking on this type of machine the water will go down to the power switch.
You can take of the top and check the fuse on the printed circuit card, in worst case you have to replace the printed circuit card.
Dec 12, 2007 | Saeco Royal Exclusive 30153 Espresso...
Saeco Royal Professional Espresso Machine Logo
513 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
