Question about Akai CFTD2083 20 in. TV/VCR/DVD Combo
32inch Akai tv
We bought this tv from a friend it is brand new I saw them turn it on and flip through the channels but now that is at our house it is asking for a parental code to unlock the tv. How can I resolve this problem?
  • Anonymous Dec 15, 2007
    jhgfj
  • Anonymous Jun 26, 2008
    i lock our tv via remote control now we've lost the remote control and we don't know how to unlock the tv. pls help
    Problem Solver:
  • 6 Answers
Contact your friend and ask for the code! if not, look in the manual and try to fix it. =]
Posted on Dec 27, 2007
My brand new Ryobi Reciprocating Saw blade clamp will not open enough to insert a blade. Rick
You are probably trying to use old-style blades in a new saw. Go back to the store where you bought the saw and ask for the correct blades.
Nov 28, 2017 | Ryobi Saws
My channel 7 keeps freezing and comes up with no signal sometimes for days when it's though my my bush digital recorder box. But when it's just though the tv channel 7 works fine. What's going on??
Different digital boxes and tv's have different levels of RF gain. Some need more signal and some need less to work efficiently.
Possibly your Bush pvr needs a much stronger signal than your tv so the available signal is permanently on the threshold of reception and atmospheric conditions will some of the time reduce the available signal when reception will become impossible for the box but still be above the threshold for the tv set.
Modern Bush is not reknown for being a high quality brand and the purchasers of budget brand pvr's often discover reception or performance problems in fringe signal areas. Because a single aerial must receive a very wide range of frequencies it will be more efficient for some channels than others and so one channel could be a fringe channel and another channel produce a very strong frequency.
The signal strength and quality can be checked for each channel by selecting options in the menu in order to check this theory.
The problem might be solved by replacing the Bush pvr with a premium brand or replacing your aerial for a more efficient type. One of my friends had five different boxes before he gained a satisfactory performance and another friend three boxes and still has problems.
My installation has a new high gain wideband aerial on top of my 3 storey house and a distribution amplifier in the loft to keep the input lead short and the whole lot connected by very good quality double-wrapped co-ax.
I had to add different amounts of attenuation for each box or tv set but in spite of the signal being on average too strong and needing attenuating there are still channels for which the aerial is not as efficient and providing only a weak signal.
Feb 09, 2015 | Bush Televison & Video
I have a magnavox CT270MW8 tv that started by turning on by it's self and flippping through the channels very fast, and when it would do this the remote control would not work nor would the controls on the...
There is some problem in semi conductor install inside TV from where it catch signals from remote, detect frequency and change and adjust your desire frequency and then your fav channel comes on screen
get it repaired only that part which receive signals from remote
If you like. Kindly rate
Sep 21, 2010 | Televison & Video
TV WON'T WORK
its an rca this is a known problem. recently on ghost story cuz owners thought house was haunted. no the tvs ir is so sensitive it will power on and change channels on its own if someone enters the room. friend probably new this was happening. there is a fix but must be authorized repair center.
Jun 03, 2009 | RCA F36650 36" TV
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
RCA TruFlat 27F520T 27" TV Flipping Through Channels
Dear Friend,
All I can suggest is to take the back cover off, and look for signs of "Bulging caps" on the PSU and look for any "dry Joints"..
Remember the tube can hold a charge of 25,000v so if you touch it in the wrong place you will be able to defy gravity.
Aug 10, 2008 | RCA TruFlat 27F520T 27" TV
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
Sharp television without remote
should be able to go through on the tv unit itself to auto search the channels, i've done in numerous times for friends in dorms who lose their remotes or don't know how to reprogram for the new cable channels. it should be on the tv by the channels and volume buttons.
Oct 09, 2007 | Sony RM-Y133 Remote Control
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Akai CFTD2083 20 in. TV/VCR/DVD Combo Logo
197 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
