Reading CD's I have several CD's that work fine on my computer but have found that some don't work. I have tried these disc's on a friends computer and they work fine.And even worse, the CD's that won't wok now worked in the past. The disc's vary from PC games, music and basic software. Hope you can help
  • 111 Answers
Are the discs scratched or fogged? if so you can take one that you don't particularly care about and use meguire's plast-x to buff out the scratches or fogging, just make sure you get all the residue off once you finish. test to see if it works now.
if this is not a cd problem and is a drive problem:
run a cd lens cleaner through your drive, this helps most of the time.
make sure you have dma enabled, even though this is seldom the problem, i have found that xp will disable dma mode if it recieves enough errors, this in turn (at least on my systems) has lead to more read errors.
if this doesn't help, check the manufacturers website for an updated firmware for your drive.
last but not least, replace the drive, a cd-rw runs about 19-29 dollars at most discount computer stores.
Posted on Nov 15, 2007
  • Trinity Sabre
    Trinity Sabre Nov 20, 2007
    just following up on all of my "helpful" ratings, is there anything i can do to further help you with the problem?
I have a RDS stereo and it won't play my cd's. It says player error
Oct 07, 2011 | 2002 Buick Rendezvous
My Sony 60 CD changer appears to have a problem with the reading eye. I have used a cd cleaner disk but does not seem to work. I would like a reliable repairman in the vicinity of Fayetteville, Arkansas....
before taking it to a repair shop, try a generous smear of nail polish remover on the cleaning disc, then run the disc in the machine may take 1 or 2 try's, but it worked for me, and several of my friends....
Sep 13, 2009 | Sony CDX-600DSP CD Changer
CD player won't play MP3 CD's?
I have had similar problems in the past - on one computer discs burned using nero were unreliable but using Windows Media Player they were fine and on other computers the Windows programme was useless and produced unreliable inconsistent results.
I suggest you experiment with different burning software and maybe suspect the drive you are using might be past it's best.
I have several cd players in my vehicles and around my home. Only a couple of them will play all the discs and most of them are very choosy and will only read premium price shop bought discs and it is a waste of time trying to play a discount store or freebie disc, or many of my computer burned discs.
I don't know what the differences are - maybe it is the software or the power of the laser burning the disc or the sensitivity of the reading laser, but there are many differences in there somewhere. The situation is very frustrating...
Mar 19, 2017 | 2000 Nissan Maxima
Cd drive not working
i have personally faced this issue before, sometimes it does happen that CD/DVD ROM's go bonkers in reading discs, mostly bcoz either the CD/DVD is damaged (scratched etc.) or the lens has gotten dirty.if it is a lens issue use a lens cleaner (lots r avail. in the mrkt) and try again if not im afraid ur CD/DVD is concked
Mar 23, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Navigation CD will not read.
Eject the disc, use a little water and a soft towel to clean it. The discs occasionally get dusty being in a car and such. be careful when cleaning though, as MOPAR will charge you several hundred $$ for a replacement one.
Dec 20, 2008 | Cherokee Jeep Grand RB4 Navigation, AM/FM,...
LG DR 165 DVD Recorder problem
hi , how are u friend
i have problem pls can y help me
lg dr4810 afiche in lcd (please wiat )
Sep 28, 2008 | LG DR-4810 DVD Recorder
Cd player will not read disc
Unit probably has defective disk motor or function sensor
Apr 25, 2008 | Audio Players & Recorders
No disc found
Most DVD players that would not recognize and/or play a disc even with a known good disc inside signifies that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves) or some other components.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 09, 2008 | Toshiba SDV593 DVD Player / VCR Combo
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Rejected discs
I had the same problem, with rejections getting more and more frequent. In the end replacing the DVD burners fixed the problem. Apparently, the red lasers that burn the cd surface fade with use. They are still fine reading the disk at low power, but burning at high power becomes progressively more hit-and-miss.
Jan 08, 2007 | Rimage 2000i CDR 2 (52X), CD Duplicator...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
