Question about GE PDS22SBRLSS Bottom Freezer Refrigerator
Fridge is not cooling but freezer is fine
I have a 6 year old GE Profile, bottom freezer, refridgerator. Fridge is not cooling but freezer is fine. Can you repair it? How much it cost?
    Champion:
  • 363 Answers
Yes ! in most french door bottom freezer units there is a fan in the freezer behind the back panel that supplies air to the freezer as well as the frig. When the DC motor on the fan wares out the rpms reduce to the point that the volume of air supplied to both components is reduced to a point that the fan will support the freezer but not the frig. The price of the fan motor alone is around $80.00, if all of the components for the fan are replaced the parts will run about $200.00, if you are not going to do the work yourself it will probably cost in the neighborhood of $300.00 parts and labor.
Posted on Jul 26, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
PDS22SBRLSS Ge Profile bottom freezer
hi is the fan motor running in the freezer. is there frost built up on the freezer wall did you pull fridge from the wall and clean the coils by the compressor
Sep 29, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Freezer not staying cold in the hot weather
Same problem as all of you. Mine happened at 17months old, not covered under warranty and cost just under $400 to have them replace the circuit board. Top of the line fridge and it is just junk! I am reading on blogs that there is a recall on these circuit boards but no one has yet to find where to call to get a free one. GE shouldn't be charging people to repair something that was bad right from the beginning whether it is past the warranty, or not. I just can't even underestand how you buy a top of the line product and you have a problem before it is even 2 years old.
I also bought a GE microwave at the same time, again, top of the line, $400 piece of junk, which I have also had nothing but problems with. It needed a new circuit board also within the first 6 months of owning it. That one was covered under warranty. Oh, and get this, the repairman had to order the circuit board rather than get me a new fridge because he says "this microwave is obselete now", are you kidding? it's 6 months old.
I WILL NEVER BUY ANOTHER GE PRODUCT AGAIN!
Jun 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refridgerator isn't keeping cold
its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Apr 03, 2008 | Refrigerators
Freezer not working again!
here is link my trouble description:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/2538-clicking-noises-back-ge-refrigerator-2.html
Mar 08, 2008 | Refrigerators
GE PDS22SBRLSS Bottom Freezer Refrigerator Logo
280 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
