Question about Lexmark P4350 All-In-One InkJet Printer
Printer wont power up.
When plugged into the mains printer power light and card reader lights illuminate but printer will not power up.Tried unpluging and reconecting without result.??
  • chill284 Aug 04, 2008
    the printer wont power up. I have unplugged it and tested the power supply the power supply works fine.
  • 2,035 Answers
Try different wall outlet if issue is same .It either printer fualt or its power adpater fualt...
Posted on Mar 16, 2008
My Sceptre x32 tv turns on normally, but the picture begins to flash on and off repeatedly. volume is not affected. I've tried several reset methods, but nothing has worked so far. Any suggestions?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 05, 2016 | Sceptre Televison & Video
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Won't turn on.
Did you get it working Jason? My MP610 did the same thing to me this morning... I went through all the rigmarole of moving it, testing it with different power cords and etc... with no success. I left it unplugged completely, tried it again this afternoon and it works. Well, it turned on, copied a piece of paper, I was able to access the ink cartridges and switched it on and off again twice and it worked. Hoping it will stay that way.
I don't know if it happened because I put a CF card in to slot - will try card in another reader first and see what happens...
I would be interested to hear what happened with yours, Jason.Cheers, Vicki 23rd April 2012
Feb 20, 2012 | Canon PIXMA MP610 InkJet Printer
My Printer HP DESKJET 2360 is offline. I tried to unplug the cord then plug it again but it wont turn on.. Please I need your help..
if the printer is showing offline on your system but printer is on, then the data cord may be defective, the wire which is connected between your pc & printer. u need to replace it. while replacing make sure both pc & printer are turned off from mains. if the printer is not showing on indication(light) then there may be fault in power supply of your printer. get it replaced.
Aug 19, 2011 | HP Deskjet D2360 InkJet Printer
Printer wont power up, 3 lights flashing on main panel when plugged in, including power button. photo,copy & the scan lights. How can i recover from this?
1. Check your wire for a possible short.
2. Reinstall your printers software.
3. Update your printers software.
4. Update your drivers
Check into the 4 of them first
Jul 26, 2010 | Dell 922 All-In-One InkJet Printer
Lexmark 2600 wil not turn on, no lights, nothing absolutely zippo. Definately has power from the mains switch so could be either the transformer into the printer or within the printer itself. have tried...
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave power cord attached to the power adapter and the other end of the power cord plugged in straight to a known working wall power outlet, bypass any surge device or power strips. There should be green LED light on around the power adapter's silver contacts. If none, make sure the power cord is properly secured. If that doesn't help, that's the main problem. If LED light is on, plug it back in the printer in the right position and properly secure it in. If printer won't automatically power on, press the power button. If that won't help at all, the printer itself is the problem. I hope I can assist you more on this.
Jun 28, 2010 | Lexmark X2600 InkJet Printer
My hotpoint wf540 will not start a cycle it very quicly steps to wash light showing but nothing happens door locked light is not illuminated.Just prior to this fault the fuse in the mains plug had blown.I...
1st you need to know if power is getting to machine, Next could be door interlock switch faulty the fact the fuse blew indicates possible short circuit/ excess current draw occured also check motor brushes assuming machine fills with water 1st
Nov 05, 2009 | Washing Machines
Hpdeskjet 940c printer
If the Power light is not illuminated, first check the power cable to ensure all connections are correct. Next, turn off the printer, then turn it on again. If the Power light does not become illuminated, the printer needs to be serviced. I believe if this doesn't work you have a bad power supply.
Jan 08, 2008 | HP DeskJet 940c InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
