Question about Belkin (F5D7230-4) Router (587009)
I can't access the Internet by Belkin Router f5d7230-4
I have Cable Modem, until 2 weeks ago It was possible to access Internt from my notbook by Belkin Router. Bu t now, it is not possible. If a conect direct to the model it is ok, but with Router I just receive signal for a local network.
Please, what a have to do to solve the problem?
Ricardo.
  • 85 Answers
Make sure your connections are right, 90% of problems result from bad or incorrect connection. If this still doesn't work, try unplugging the modem and router, leave it off for a couple of minutes, then plug everything back in. If this still doesn't work, try your local computer repair shop and see if they can futher assist you. Hope this helps! If you have any questions, send a comment
Posted on Jul 12, 2009
I bought a Belkin 'Play' router to provide wireless internet connectivity from my CLEAR modem. I can't get the router to speedtest at half the speed as being directly connected (via ethernet cable) to the...
Use an Ethernet cable from the CLEAR modem into the WAN (or 'Internet') port on the Belkin.
Take a close look at the 8 coloured wires at each end of the Ethernet cable.
The 8 wires must be coloured in the _same_ order at both ends.
Be sure that you have a 'CAT-5' or 'CAT-5E' cable, not a 'CAT-3' cable, which is much slower, over long distances.
Use another Ethernet cable from one of the (three? four?) 'LAN' ports on the Belkin to the network-port on your computer. Again, check that you have a "straight-through" cable, not a "cross-over" cable.
Turn the CLEAR modem off.
Turn the Belkin off.
Turn your computer off.
Turn the CLEAR modem on, and wait until its lamps settle-down to a consistent pattern.
Turn the Belkin on, and wait until its lamps settle-down to a consistent pattern.
Turn your computer on, and let it boot.
You now should have Internet access.
Note that the router "dynamically" shares the Internet connection.
If there are 4 'LAN' ports, then each of the LAN ports gets as much speed as it needs;
you do not have a 25/25/25/25 split, unlike cutting-up an apple-pie to feed 4 people.
Run a "speed-test" on your computer, and you should be getting as much speed as you are paying for. Having the Belkin in the "middle" of your network should *NOT* slow-down the speed-test at all.
Apr 04, 2011 | Belkin (F5D7230-4) Router (587009)
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Modems
I would suggest a Belkin Wireless G or Pre-N router, hawkings is also good to use.
Hope this works.
Dec 24, 2007 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
230 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
