Question about SanDisk Sansa Fuse MP3 Player
Sansa Fuze not being detected
When I plug my Sansa Fuze into my computer, it isn't detected. This won't do, because I want to put more music on it, and it's also my only method of charging it. What do I need to do?
    Sergeant:
  • 449 Answers
Try using it with Power Switch to ON position. Ehtesham.
Posted on Jul 12, 2009
My sansa charger isn't working ? what should i do?
Posted on Jul 17, 2009
Sansa Fuze not Regestering Songs
The device only likes mp3's. Most other files don't show up.
Apr 13, 2010 | SanDisk Sansa e260 MP3 Player
Sansa Fuze player will not connect to the computer
The Sansa Fuze information support is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze can connect in either MTP or MSC mode.
MTP is Media Transfer Protocol when a software program like Windows
Media Player 10 or higher is installed.
MSC is Mass Storage Class when the player is detected as an external flash drive in "My Computer".
The connection mode can be set to one of the following USB modes:
auto detect:
the player will connect in MTP or MSC mode. It depends on the drivers that are installed for the USB ports for the operating system and extra media software, if the data on the player can be detected. In auto detect
mode, MTP mode detection is only possible when having Windows Media Player 10 or higher installed.
mtp:
detection on operating system Windows XP SP2 or higher, in Windows Media Player 10 or higher.
msc:
detection on operating system Windows in the explorer in "My Computer" and on MAC operating system.
Look in the manual on page 35 = page 38 in the pdf file, how to switch the USB mode under System Settings in the player:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
I don't know how to download music on my sansa fuze (4GB)
On your Sansa Fuze, go to the "Settings" menu, then go to "System Settings", then go to "USB Mode", then select "MSC".
Now, connect it to your computer, then double-click "My Computer" on your computer's desktop to run Windows Explorer. You should see your Sansa Fuze show up as "SANSA FUZE". Double click on "SANSA FUZE", and you should see a folder called "MUSIC". Copy your music into that folder. When done, unplug your Fuze and your music will be on it.
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
I don't know how to get music onto my Sansa Fuze.
There's a Sandisk support site for the Sansa Fuze, see:
Sansa Fuze user manual in pdf format:
Important
There are 2 ways the Fuze can be connected to a computer to transfer
music: MTP mode or MSC mode, read page 16 (=13) of the manual.
The player can be set to automatic detection of the connection mode
or can be set to either one of the available connections.
MTP mode is used for transfers using software like Sansa Media Manager or Windows Media Player 11.
MSC mode is used for transfers using the "drag and drop" method in the computer's explorer.
Need more help ? Just post a comment.
Dec 22, 2009 | SanDisk Sansa Fuse MP3 Player
Sansa fuze 8mb format and firmware update
go into device manager in computer management and uninstall the sansa driver. Restart the computer and plug it in again
Jul 15, 2009 | SanDisk Sansa Fuze MP3 Player
Computer will not read Sansa Fuze
did you try to connect from your sanza to onboard usb don't use the front of your pc usb maybe wrong setup or wrong connecting the wire . use the usb located at back of your pc , if you connect the sanza to you pc if have words appear ( found hardware)it mean the sanza need the software driver and you unable to detect without driver..
Jul 05, 2009 | SanDisk Sansa Fuze MP3 Player
The computer wont recognise my mp3
try messing with the usb settings on the mp3 player in settings/ system settings/ USB mode/ for a newer PC try MSC for an Older PC or mac try Mtp and if that dosen't work try auto detect just mess around with it fir a while
Apr 09, 2009 | SanDisk Sansa Fuze MP3 Player
Sandisk sansa fuze mp3 4GB* (red) won't work right
we just got a sansa fuze and downloaded media player but its put everything photos and music from my husbands computer on to it, its for my son how do we remove it all? HELP!
Feb 20, 2009 | Audio Players & Recorders
Sync problem sometimes works and sometimes doesn't
I used Windows Media Player 11 to move music to my Fuze.
  1. Plug your Fuze into an USB port on your computer using the provided adapter cord. Windows will detect the Fuze and install it if need be.
  2. Once Windows has done its thing, open WMP11 and select the "Sync" tab.
  3. You can now drag and drop your music from your Library on the left to your Sync Playlist on the right.
  4. Once you've moved your selections, click on the "Start Sync" button at the bottom of the right side.
  5. The music will be uploaded to your Fuze.
You can have WMP11 detect your music and put it into your Library by pressing the F3 key. Press F3, navigate to your music folder with the Add button, and then press OK. You can remove folders from the list in the same manner.
Feb 04, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze
i had the same problem putting on music and what i eneded up doing was coping all my music to a memory stick and using a differnt computer. if you want you could buy a microsd card reader and format the card to put music on it and then just sync the computer to the card and that should work just as good.
Jan 07, 2009 | SanDisk Sansa Fuze MP3 Player
Open Questions:
SanDisk Sansa Fuse  MP3 Player Logo
435 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
