I'm using a dish network remote control echostar 180552
SOURCE: magnavox converter box codes
There are no available codes for these, if you are using an universal remote, use the scan function. Typically when scanning you hold down setup on the remote, press SAT/Cable, then power. If it doesn't shut off the box, you press Channel up, and power again. Repeat the Ch. Up and power to keep going to the next code. When you do find the correct code the converter box will power off when you hit power. Press Enter on the remote to store that code for SAT/Cable. Enjoy
SOURCE: can you turn on a magnavox dtv box without a remote control
No. it need a remote control to operate.
SOURCE: I need the code to use a magnavox converter box with a sanyo remote control
2901,2998,2917. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
