Question about Hotpoint VBSR3100GWW Top Load Washer
How do you remove the agitator from a top load washing machine? model VBSR3100WW
  • Hotpoint Master
  • 3,361 Answers
Simply pull up very hard it will come loose. You might want to try and old leather belt or strap under the agitator and pull up.
Posted on Jul 12, 2009
Remove agitator from top loading moffat washing machine
remove the top snap and then about 6 inches down there should be a 7/16 screw nut that has to be removed, then the agitator can be lifted out but may need some real force so may want to use a pc of rope under it to pry it up? may also have to remove another bolt at bottom as well as thrust washer to pull rest of agitator out on some models that have a 2 pc agitator
Dec 18, 2014 | Washing Machines
How to remove the washplate (agitator) to remove loose change .I have removed the plastic cap and removed one bolt but it still doesnt lift up, help
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137800&diagram_id=28247413#d28247413 The Impeller or agitator can be removed from the washing machine by pulling the top cap off of the impeller or agitator and removing the 7/16" bolt that is hidden underneath. This will allow you to examine and replace the agitator roller cams or lift the inner wash basket out to access the outer tub, tub sump, and lint filter for cleaning.
Dec 27, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a procedure for removing the agitator(s) on top load washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
Nov 04, 2009 | Kenmore Washing Machines
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
Agitator is slipping
I have a different model, but my agitator came off with brute force. I used 2 allen wrenches in the slots on the side of the agitator to get leverage and then yanked until it came off. The problem is your air bell coupler.
Jan 30, 2009 | GE WJRR4170E Top Load Washer
Agitator on my washing machine is not rotating the way it should. It seems something is not catching and the piece is only rotating part of the time.....please help. ps How do I remove the agitator to see...
Remove the cap off the top of the agitator. Then remove the 7/16 bolt below. Your problem is inside the top part of the agitator. YOu need to buy an agitator dog kit. When the part is removed you will see how to put it in.
Dec 11, 2008 | Kenmore 15944 Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Dec 03, 2008 | GE WBSR3140DW Top Load Washer
Hotpoint VBSR3100GWW Top Load Washer Logo
147 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
