Brewer will move in & out of neutral position but when in neutral the brewer will not go back into the machine as the wheel/bearing is not in neutral and will not move. Needing to find a way to get the machine to allow wheel to move manually or operate on it's own without brewer inside of machine.
There is a reset procedure you could find in the technical manual. I sent it to your e-mail. The difficulty is to get into the "programming" mode. When they say "Switch the appliance off" at page 89, they mean switch off the on/off switch inside the machine (upper left corner). Good luck.
Michel
Quite a problem. Now, I guess it's not easy to contact a particular user familiar with all this procedure. Su maybe you should contact MIELE.
Home
WEBSITE HAS A "CONTACT US" . Might be iusefull to contact them and expalian them detailed issue
Testimonial: "I already have and they want to do service call which is outrageous like $300-700 just to come out and look at it. The machine came with our building so there's no warranty on it either."
