Question about Two-Way Radios
I need a scamatic for a teberry stalker xv cb radio
Vintage cb radio teberry stalker xv i need a scamatic.
    Problem Solver:
  • 12 Answers
Re: i need a scamatic for a teberry stalker xv cb radio
Ok i have the service manual for the stalker xv ill scan it for you and mail it to you
Posted on Nov 19, 2007
    Problem Solver:
  • 20 Answers
I assume you have already checked out cbtricks..... they have about 20 or so teabery schematics/mods and whatever there.... possible they don't have yours.
I have a bunch of old Sams photo fact manuals around the shop here.... all of the Sams I have are all old radios... mostly tube. So there is a chance I might have a Sams photofact that has your model in it.
So if your really stuck.... I might be able to take a look what we have here and scan a copy for ya.
I'll take a quick look on line at a few schematic website I use regularly and see if I can find a pdf for your radio.
If your really stuck ... I can look through those sams we have here .
Let me know.
Posted on Nov 16, 2007
0 characters
3 Points
When car is on the cb is on but wont show no reading or show my channels
check your PA/CB switch and your microphone connection, I don't know this specific radio, but these are the two primary items that can cause this issue on most cb radios.
Oct 16, 2013 | Cobra 19 Ultra Iiie 40channel Compact Cb...
Need a repeater for 75-822 Portable/Mobile CB
there are no repeaters for CB radios, they are not legal, nor Are CB's capable of using them.
Oct 08, 2013 | Midland Two-Way Radios
User Manual
CB radios are incredibly simple, any decent CB shop should be able to set you up with a power cable and show you how to use the radio.
Jul 06, 2013 | GE Cb Radio General Electric 2 Way Radio...
How can I make the 19DXIV VHF capable
There is no way to make that radio VHF capable, CB radio's operate in the AM band, and most, if not all VHF radio's operate in the FM band. CB radio's are not capable of VHF frequencies either, VHF is considered around 40MHz and above, CB radio's operate between 26.965 MHz and 27.405MHz that is considered 11 meter band HF. CB radio's are not broadbanded enough to cover anything that far away, expecially the newer radio's, as most of them are controlled via a microcontroller and PLL tuning circuit. the 19DXIV is a great little radio, but will never be able to operate in or even around VHF. sorry.
Oct 21, 2012 | Cobra 19DXIV 40 Channel Mobile Compact CB...
I can't get my walkie talkie to go it's full 20 miles its only reaches maybe 3 miles or so it dont make any scence to me. also how can i comunicate with cb's in semi's
The distance claims made by FRS/GMRS radio manufacturers are fairy tales. The frequencies that these radios operate on are line-of-sight only, meaning that ANYTHING between the radios (buildings, hills, trees, etc.) will block the signals. Unless you're transmitting from one hilltop to another, with nothing between the two, 2 to 3 miles is the maximum effective distance for any of these radios.
On your other question, FRS/GMRS radios and CB radios operate on different frequencies bands, so you cannot communicate between the two types of radios. In order to communicate with CB radio operators, you will need a CB radio.
Bill B
Listening in since the 60's
Sep 22, 2010 | Cobra PR 4200 WX (22 Channels) 2-Way Radio
Makes a squlesh sound like a CB radio when monitoring radio or transmitting
GMRS transceivers, yes - like CB radios, have squelch or threshold tuning circuitry. Without it you would be listening to an irritating hissing noise between transmissions, and the radios would not be able to scan. The big difference is that the squelch setting on a CB is adjustable, but it's automatic on GMRS sets.
Dec 24, 2009 | Uniden GMR1838-2CK Two Way Radio
How can you talk to cb radios?
with another CB radio only. A midland 2 way radio is gmrs and is a much higher frequency then CB. not compatible.
Sep 25, 2009 | Midland LXT310 2-Way Radio
Will it work with a cb radio
No. CB's operate at the 27 MHz on 22 predetermined frequencies allowed for Citizen Band radios; and your Motorola XV1100 radio is a VHF 150-170 MHz radio with a set amount of built in frequencies to choose from, designed for business use.
Aug 20, 2009 | Motorola XV1100 (1 Channel) 2-Way Radio
Solder connections broke inside of radio you will have to take apart an re solder check with magnifying glass
Apr 13, 2009 | Motorola Two-Way Radios
Excalibur SSB base radio will work fine one day,not the next.
Might be worth checking the microphone cable on the transceiver, specially near the plug, or the push to talk switch. I saw this umpteen years ago with a CB that was intermittent.
High voltage capacitors are a bit hard to find but look on the net for vintage radio suppliers. While you have the tube radio open, look for resistors that gone high, this can put higher voltages than design on the caps and of course can quickly wreck tubes that were otherwise OK.
Apr 27, 2008 | Two-Way Radios
Two-Way Radios Logo
248 people viewed this question
Top Two-Way Radios Experts
Are you a Two-Way Radio Expert? Answer questions, earn points and help others
