Question about Microsoft Xbox 360 Wireless Controller
My controller do not work with my x box 360
Every time i turn the x box on the green light on my controller go off in on
  • 51 Answers
It might be the battery on the controller or the bottom corners of your battery holder on your controller, if there cracked or broker then youll need some duct tape or electrical tape id reccoment a new controller if thats the problem, also replace the batteries. there is a slight chance there bad, if all else fails and you still ahve the receipt then you can send it in and get it replaced/fixed. hope this helped
Posted on Jul 12, 2009
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
I have an X box 360 controller for PC butthe green light flashes and it doeasnt work- can anyone help ??
hello,
-If its a wired controller to USB then should not flash as long as you dont press the big green X button with your drivers you installed.
-If its a wireless controller, you need to purchase the adapter they sell for PC use.
cheers
Feb 26, 2011 | Microsoft Xbox 360 Controller
When i turn on x box 360 the green center light appears but the four side lights to not ( no ring). I can open and close the disc on x box but nothing shows up on the tv.
Are your controllers connected to the xbox? that is how you get green light bars around your main green light bar. If you are not refuring to this and nuthing is showing up on your tv screen but you have sound try ajusting/ spinning around the yellow av cord ( Yellow cord is what projects pictures onto screen) . Hope it helped. =]
Nov 03, 2010 | Microsoft Xbox 360 Console
When I try to turn on my xbox 360 my controllers do not connect to it. I get the green power light on the front of the xbox 360 and four flashing green lights on my controller. I have tried my...
Press the circle button in front of your xbox 360 and at the same time press the small circle button on your controller ( located near the port where you connect the play and charge kit cable) so they can sync with each other
Sep 16, 2010 | Microsoft Xbox 360 Console
Game loads okay but controller does not work. controller is brand new. lights work on controller but can not ply any games
If the controller is brand new, you need to Sync it with your XBox 360.
Turn on your 360 using the button on the console.
Turn on the controller by holding the X button in the middle.
With both on, click the SYNC button on the xbox 360.
Then click the SYNC button on the Controller.
The green ring around both should flash a few times, then the upper left quadrant should light up on both meaning it's Sync'd.
Enjoy.
Mar 17, 2010 | Microsoft Xbox 360 Wireless Controller
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
My xbox 360 AC adapter is in yellow light and the console is not working, what i do to make it to chage to green light?
If you have no power to the console or the console itself is not powered on then the light will not turn green. In other words...until you can turn the power on to your xbox 360 the light will remain yellow. Check the connection to the back of your 360 it may have wiggled loose somehow. The instant that the power brick senses power making a complete cycle in your 360 your light will turn green. If the 360 fails to turn on when you push the power button or when you push the center button on your wireless controller or when you push the center button on a wired or wireless controller that is connected physically to the 360 then I hope it is still under warranty. If not then you should contact someone about how to repair this issue. It may be that the power button is the only thing broken on this machine.
Oct 25, 2009 | Video Game Consoles & Games
X-box 360 wont turn on
Is your power box light orange or green. It should be orange if turned off and go green when turned on if it is red your power supply box is no good you can unplug it leave off for 10 minutes or so then try again if light doesn't go orange you won't be able to turn it on. I had the same problem and it was power supply box with red light got new one works great.
Jul 17, 2008 | Microsoft Xbox 360 Console
Xbox 360 wireless controller
You must sync the 360 with your controller. Turn on your 360 and your controller. Push the little black button on the front of your console, then hold the little tiny button on the top of your controller for a few seconds. This should sync them.
May 19, 2007 | Microsoft MS Xbox 360 Common Controller...
Microsoft Xbox 360 Wireless Controller Logo
192 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
