My unit is 9 years old Ruud RCGA-60AIGH24B seems
My unit is 9 years old Ruud RCGA-60AIGH24B (coil) seems to be clogged and/or the pan is leaking.unit is freezing up. Does not cool house though fan blows. What is a reasonable cost of repair or replacement? Should I replace the AC full unit & relative costs of replacing coil or replacing full unit?
  • 158 Answers
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Posted on Jul 12, 2009
My lennox elite series cb29m-41-1p is leaking alot of water in the house with the air conditioner on. drain line to outside is clear
The condensation pan in the unit must have no cracks our brakes, and needs to be tilt down toward the condensation drain line, algae builds up clogs and must be cleared of clogs periodicaly
Aug 05, 2017 | Heating & Cooling
I have a ruud silhouette furnace. it's been here in the attic since the house was built in 2001. There is a metal pan around the base of the furnace and it keep filling with water.I see where the wate
The water is condensation from the evaporator coils and is normal. There should be a drain pipe or hose from the pan either to the outside of the home or into the wastewater drain. It is also normal for dirt to accumulate on the evaporator coils and some of it ends up in the pan and clogs the drain. Cleaning the coils and flushing out the drain is something that should be done at least yearly.
Sep 12, 2014 | Heating & Cooling
Ceiling leaks
coil is dirty or frezing up allowing water to leak.
Jul 07, 2013 | Ruud UBHC Air Conditioner
My ac unit is leaking through the coil box, I cleaned the drain, but it still leaks from the side of the box. Could it be cracked? the unit is 9 yrs old
Could be a cracked condensate pan. this may require replacing the pan or there are sealing sprays on the market which you can buy at HVAC stores.
Dec 11, 2012 | Weather King Heating & Cooling
Condenser pan overflowing
Do u mean the evaperator drain pan.Were is it located in attic or in house closet.Because the condenser fan motor and coils are located outside.BUT ANY WAY DRAIN LINE MIGHT BE CLOGGED OR IN PAN-BLOW COMPRESS AIR INTO DRAIN LINE.CK END OF PIPES FOR CLOGG.
Sep 15, 2012 | Ruud UBHC Air Conditioner
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
I have a 5-year old Goodman furnace/AC. It has a drain trap on the side which looks like a cup with 2 hoses coming into it from and a drainage pipe coming out into the sump pump. Recently I noticed a...
Hello, it sounds like your condensate line is clogged and not be able to drain into the condensate pump or your condensate pan is cracked and leaking. Best thing to do is clean the condensate line with a shop vac and see if the water will start to drain, if not looks like the pan is cracked.
Jul 13, 2011 | Goodman GMS90703BXA Heater
Leaking inside. Fedders A3X05F2A-J Unit is sloped away from house. Have sprayed coils. Doesn't seem to be drain hole at back of unit
Mellisia, the problem very well may be, that the drain pan hole under the unit, on the outside may be clogged. When that happens, water backs up and leaks out the front of the unit.The drain hole should be near one of the corners of the drain pan. And with Fedders, it may be on the edge/lip of the drain pan. The clog, may appear to be part of the drain pan and that's why you haven't noticed it.
Inspect the drain pan closely. If you can't find it. You can create one, by CAREFULLY drilling a hole at one of the corners of the drain pan. It doesn't have to be a large hole 1/8" to 1/4" should do.Be sure the unit is OFF and unplugged from the wall, before attempting this. Also, once the drill bit penetrates the drain pan STOP. You don''t want the drill bit to pierce the coils on the back of the unit.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Fedders A3X05F2A Air Conditioner
Heating & Cooling Logo
283 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
