Coby TFDVD1595 15 in LCD TVDVD Combo Logo
A
Arno Posted on Aug 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there any code for Philips remote for Coby TV/DVD combo model TFDVD1595 that works? I've tried everyone that I've found so far. Only get volume to work on any of them.
richie46
Level 3:
Top Expert:
  • Coby Master 12,962 Answers
  • Posted on Aug 31, 2015
richie46
Coby Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945363
Points
58151
U are at the mercy of the universal remote and will have to locate a another universal that will give you more versatility than the Phillips.
But do not expect much from the universals - they only have the most basic command such as volume, mute, channel, work.
1helpful
Philips Z11 TV/VCR Combo. I need the 4 digit universal remote code for TV VCR please.
I don't think you will get that to work, you have two units in one box
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
'Z11' doesn't seem to be the correct alpha numerical model number.
https://www.google.com/search?q=philips+z11+tv%2Fvcr+replacement+remote
Save Code list for future reference Refer to the setup ...
Philips https://www.p4c.philips.com > files > sru4000_17 PDF Save Code list for future reference Refer to the setup procedure below and look up the 3 digit code for your brand of TV, VCR, etc., from the list below.
2 pages
Missing: z11 ‎' Must include: z11
Philips 4 digit remote codes for Combo devices - eliztech.com
eliztech.com https://www.eliztech.com > remotes > philips-4digit-co...
Four digit code lists for HTIB and TV/VCR/DVD/DVR/SAT/CABLE Combos - Philips universal remote controls.
Philips Universal Remote Control Programming Instructions
directutor.com https://www.directutor.com > content > philips-sru210...
Program your audio and video devices with Philips Universal remote codes, simple steps for programming Philips universal remote...
Need remote code for Coby TFDVD1595
Hi Anna, my name is Kimberly and I form part of the Social Media department with DISH. I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at [email protected]!
You can lookup codes if needed here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Need codes for COBY TFDVD1595 tv/dvd to rca universal remote(RCRN04GR)
Coby TFDVD has no setup codes with any of RCA universal remote controls.
I lost my remote and need a remote code for a universal remote
To get the codes for your TV
Please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Select the remote control model,Device and Brand,It wil give you the code.
Thanx
I have a EWC19T3 tv/vcr/dvd combo my ex-boyfriend threw the remote and shattered it. I have a philips/magnavox universal remote but I've tried all the codes listed for emerson (which is a lot) and none of...
Unfortunately, the remote you picked up may be incompatible with your current TV. (I found older universal remotes didn't work with my newest set that had a digital tuner. These were remotes that worked with ~20 year old tvs (analog only). Similarly a new remote might not work with an older TV. Then you get stuck with the result you have.)
Remotes.com has a substitute remote that has all of the functions of the original remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWC19T3&uuid=12792355576670
This one will work.
Your TV has Select, volume and channel change buttons on the front of the TV. So a tedious way to deal with the problem is to move to the TV to change channels. The Volume controls are under the DVD tray. Select (toggle TV/VCR, DVD, and external input) is the first one on the left under the VCR cassette slot. The channel up/down is to the right of the Select.
I wish that I could be of more help.
(However, you might try the Philips Remote Code Finder: http://www.urc.philips.com/ and select your country and click on the right arrow. Then find your remote model and see if you can get a single number for your TV. On the newer remotes I looked at, it only returned a code of 0917 for All Emerson devices.)
Tv dvc combo remote codes coby tv
hi! i have here a two codes for your coby tv 1460, 2380. just try them hope this helps! goodluck!
5helpful
Philips universal remote not working for my coby dvd 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
