Question about Proform Exercise & Fitness
Proform xp 110 machine ,ac adaptor??
I have a proform xp 110 machine and i`m tryng to hook up a 6 volts transformer to it, would like to know the polarity of the jack and amperage,i don`t have the manual any ore thanks LUIS..
jgwhomeequip
  • 1902 Answers
SOURCE: transformer 110-220
Less expensive to replace the heating element. But if you already have a 1000 watt transformer then just go that route
Posted on Feb 22, 2009
  • 11 Answers
SOURCE: What is correct AC adaptor for a Belkin USB Pocket Hub F5U007?
AC Adapter (100-240V, 50/60Hz)
Posted on Jun 25, 2009
SOURCE: Compaq Armada 7400 AC Adaptor Pins
the part number for 7400 power adaptor is 204434.001
Posted on Aug 28, 2009
  • 10865 Answers
SOURCE: need to know size of ac power cord to get ie.
hello. Your proform can be operated on electric or with 4 D cell batteries. If you do not have the power supply cord that comes with this unit you must order one from the company. The information on how to order one from the company is at the end of the manual. Here is the manual:
http://fitness.manualsonline.com/mdownloads/ae475852-929e-4cad-8d5a-1ac56f09731a.pdf
Kindly rate my answer. thankyou.
Posted on Feb 03, 2010
shaddow4115
  • 105 Answers
SOURCE: Need to know Amps & Volt. for Simpletech "Simple Drive" 1Tb.
The output of your adapter is 12volts 1.5amps the outside terminal is negative polarity and your connector looks like this (see below)
4927b50.jpgThere are two options of adapter (see below) both will work
EBAY Search for your adapter
Posted on Feb 13, 2010
I want to use this Transformer to power my 12 volt lights in my trailer using a 7 blade connector that is already installed on my trailer. How do I connect the wiring n the ac nle
The two wires are meant to be connected to the 120 volt source. The box or the papers with the transformer should tell you which two of the three wires provides the 12 volt output. If not connect the two wires to the 120V source - Be CAREFUL! - 120V is dangerous. Then try, one at a time, touching each of the three combinations of wires (1&2, 1&3, 2&3) to the contacts on a 12 V incandescent lamp (very bottom and threaded side) the 12V pair will give you the brightest light. The other two are 6v.
I can't address the 7 blade connector without more information. I suggest that you go to a place that sells trailer parts.
Not knowing anything about your trailer I don't know if a 2 amp (2000 ma) transformer will supply enough current to do the job.
Nov 19, 2013 | Philmore TR212 12 Volt AC Power...
Proform 3001 stx transformer information
HI,
You can find the AC adaptor for your transformer in the following link.Its spesifiaction is not listed anywhere else.
http://www.fitnessrepairparts.com/cart/ViewItem/6000550
Apr 26, 2012 | Exercise & Fitness
I bought a GE microwave oven model wes1450dm1bb at the USA, but now I am in a different conutry that uses 220 volts as standard. I just read the user manual and in any place says the voltage of the...
No, You'll burn up the appliance. When I was in Germany there were commercially available transformers to step the current down. The transformers plug into the 220 sockets and provide several 110 sockets to plug your appliance into. We purchased several transformers and ran our 110 tvs, kitchen appliances and other 110 appliances. The 220 sockets in Germany were different than 110 and 110 plugs sould not fit.
Feb 23, 2011 | Ovens
Blown power supply for this model, can we get a power ac adapter?
"blown power supply for this model, can we get a power ac adapter?"
If you are using this machine in the US or Canada, you need a step-up transformer.
That is, a transformer that can raise the local 110 Volts AC to the 220 Volts AC your Canon FAX-JX200 needs to operate.
Your faximile consumes about 50 watts when operating.
The power output of this transformer should be such that it does not get more than just warm to the touch after half hour of operation.
Any self-respecting retailer should be able to provide you with a suitable transformer for under $20.00
Please feel free to contact me if you wish.
Thanks!
Feb 13, 2011 | Canon FAX-JX200
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
Sylvania GNET28001SO Meso 8.9" Netbook PC (1.6 GHz Intel Atom
If you are attempting to connect your laptop between 110 and 220 volt power outlets, you may be able to do so already, take a look at your power cord's transformer (brick) and read the input voltage. If you only can use 110 volt AC Input Voltage should read 115VAC. If you can do both, then it should read 110-225VAC.
If your power brick supports 220, then all you will likely need is a plug adaptor, found at many electronics store. If not, you wil need to stop in at a computer store or an import store and get an international transformer, which are set up to convert many different country plugs and many common voltages.
Good Luck!
May 06, 2009 | Sylvania Meso GNET28001SO Notebook
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Exercise & Fitness Logo
637 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
jay kaye
jay kaye
Marvin
Marvin
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
