SOURCE: PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
SOURCE: TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
SOURCE: I have a Philips 42PF7320A. The menu is stuck on
try softwear update if not ssp pcb call phillips for soft wear
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
SOURCE: tv not letting remote work. Have 2 remotes it is the TV. Philips
what you have is a bad IR sensor board. The part # is:
313926859182. Right now, there are so many of these things failing, that finding the original might be difficult.
Don't
fear, though; it's a small part. And, best of all, it's cheap. Expect
to pay around $5.00 for the part, maybe a bit more, maybe less,
depending on the supplier.
Now, if you are handy
with a power drill (fitted with an octagon/star bit for the back of
your set), you can remove the 20 or so star-bit screws from the back of
your television. Don't worry about putting the set on the floor. If
your TV
is on a stand, simply turn it around. You'll need to remove the stand
screws, but you won't need to take the TV off of the stand.
Now
that you've taken the screws out and removed the back cover, look in
the lower left hand area of your set. You'll see a 4 inch long circuit board with 2 cables running to it. Pull the cables out (they'll come out easy). Remove the 2 star-bit screws.
One of the board's sides is under a plastic tab. Lift the board out of its slot from the other side.
Put your new board in, reconnect the two cables, reassemble the back and you are set to go.
Expensive repair for a few bucks and a better IR sensor.
