Question about Garden
I can not loosen the spindle bolt on my Cub cadet LT 1500 that would allow me to slip a new drive belt up on to the top pulley. The power start mehanism and bottom pulley have to drop down a bit to allow me to get the belt up to the pulley.
  • 45 Answers
Is that how your manual recommends changing the belt?
On most riding mowers, the deck must be lowered in order to replace the belt
Posted on Aug 14, 2009
My mower Cub Cadet GT 1554 stopped moving. I found a plastic thing that looks like abfan on the ground
The transaxle (transmission) has a fan fastened to the drive pulley. It is possible that you belt has jumped off of the pulley on the transaxle and this broke the fan.
Jul 05, 2017 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
I need a schematic for installing a cub cadet LT1050 drive belt. The old belt broke and I'm just not sure how to replace it. It appears you need to remove the clutch for the mower blade firat.
To replace a transmission drive belt on a Cub Cadet LT1045 or LT 1050 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ), use an impact wrench (you need the speed of the impact wrench because the engine will turn) and a 5/8" socket and reverse the bolt out of the PTO.
The PTO may be sized on there so you may want to tap it with a hammer and a block of wood carefully to release it. AT this point remove the 4 engine mount bolts from underneath (1/2" I believe). You will need to remove the left steering nut and arm to have access to the 4th bolt. Do not remove or replace engine mount bolts with impact wrench or bolts may break. Loosen old belt from tensioner pulley. Place pry bar under engine to slightly lift engine and move aft to expose belt from pulley and remove from pulley. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, draw a map if needed.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Carefully push engine back into place and exhaust pipes into forward muffler will take some patience. Bolt engine back on being careful not to over tighten bolts. Place steering arm and nut back in place. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO is "keyed" on the shaft. Replace bolt and washer. Put your deck back on and you're ready to mow again. Give yourself an hour for this one.
Aug 16, 2014 | Cub Cadet Garden
W w w google
I was able to get the electric clutch and pulley off using a 3 point puller, but couldn't get the pulley above it to budge. Needed to move it so I could put a new drive belt on. Ultimately I decided to remove the (4) engine mounting bolts and slid the engine around a little to allow me to put the belt on, then put the engine mounting bolts back in. If that's -why- you need to remove the drive pulley, this should work for you. Good Luck!
Jul 14, 2014 | Cub Cadet Garden
Installation of motor drive belt on cub cadet tractor
This one's a PITA. That said, I had to remove the PTO clutch and pulley, the seat, the brake and transmission pedals, and finally the sheet metal that constitutes the fenders and foot plates.
Belt is put over the fan above the transmission and onto the pulley there, then run along bottom of main frame towards the front until it reaches the engine drive shaft.
The belt goes onto a pulley on the engine drive shaft (above the PTO clutch and pulley, which have to come off). I couldn't slide the drive pulley down the shaft, so pulled the 4 engine mounting bolts and move the engine around slightly to allow putting the new belt on between the pulley and it's surrounding sheet metal. Once the belt was on, and before any other steps, I realigned the engine mounting holes and replace the bolts.
The belt is then run around the pulleys under the middle section of the tractor. Leave the spring loaded idler pulley for last. you might need to loosen (not remove) the bolt that goes through the idler pulley in order to get the belt on. The biggest fight is pulling the spring loaded pulley over so that you can put the belt onto it.
Once the belt is fully routed over all pulleys. Reinstall everything that you had to remove - and you should be good-to-go.
ONE LAST COMMENT: Many shops sell belts that DON'T have Kevlar. Make sure you but the one WITH Kevlar. The others rarely last one season.
Aug 31, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
I want to change the transmission belt on a Cub Cadet LT 1045. Everything looks pretty straight forward except the engine pulley. It looks like engine has to be unbolted and lifted high enough to get the...
You can carefully bend back the guides on frame, push in the clutch pedel and secure it with a piece of rope or a bungee cord. (this allows slack in the belt to remove it.
If you wanted to loosen the motor which is time comsuming, you would need an impact wrench to loosen bolt on pto
Nov 15, 2009 | Garden
Trying to change drive belt on cub cadet ltx 1045.
convert?ilfn=d%3a%5ccatalog%20data%5cemp_img%5cccp2%5cimages%5c04%5c76904756%5c0003.tif&ilsc=23&iliv=0&ilbr=0&ilif=p&ilre=8 What i use is a SMALL pipe wrench to fasten between the big pulley and little pulleyand let it jam against the front crossbar that the spindles are attatched to or equivalent
then you can remove that bolt with a 6 point socket shallow or deep well
comes out ccw and is torqued back to 55 ft.lbs.
Jun 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
165 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
