Question about Casio EXILIM Card EX-S770 Digital Camera
EX-510 Powers up, them immediately shuts down
I press power, the lens extends, "memory full" is displayed, then shuts down. There are three mechanical 'zipper' sounds when the lens is fully extended, definitly not normal, also several beeps during the whole process, which takes about three seconds. It started after the bottom corner nearest the lens was submerged briefly in the lake. Camera was dried with battery and card removed for several days. The camera will review pictures though. Can anyone help?
I have the same problem is there a fix? marksugar@aol.com
Posted on Apr 29, 2010
Lens wont go in power button wont lite or come on and screen display nothing what is happen to my fe 210 olympus camera
I have the same camera! But my display is broken. :( But it still works. Try plugging in the external video cable to see if you can see the display on your TV.
Make sure the battery is fully charged. If the battery is no longer holding a charge, replace it or use the appropriate AC adapter to power the camera.
Also, remove the memory card if you are using one in you camera.
After you put a freshly charged battery in or plug in the AC adapter, press and hold the power button for at least 3 full seconds. The lens should extend fully. If it doesn't, press the playback [>] button on the back (this should make the lens retract). Then press the power button to shut the camera off. Press the power button again to power it back up and the lens should extend out as normal. You should be OK.
If not, let me know and I'll see what else I can dig up.
The last thing you can try is updating the Firmware. Below is a link to the Firmware update for this camera. Since I don't know what OS you're using, just pick your Operating System and follow the instructions on the pages that follow the link you chose.
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1300
Dec 04, 2010 | Olympus FE-210 Digital Camera
Camera does not power on. I get three beeps,
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 22, 2009 | Canon PowerShot S2 IS Digital Camera
My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Oct 07, 2009 | Kodak EASYSHARE M340 Digital Camera
Power on, boots, then shuts down
I believe you have a defective Exilim memory card. Try replacing the memory card and see what happens.
Mar 27, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Casio Z750 says, "Lens Error" on start up, and then shuts down?
A lens error has to be sent into repairs or else you need to buy a new camera. Repairs is 800-706-2534 and then choose extension for repairs.
Nov 28, 2008 | Casio Exilim EX-Z750 Digital Camera
THE LENS OPENS AND CLOSES QUICKLY DOES NOT LET ME TAKE PICTURES EXS880
Two possible solutions:
1: Lens Error----If the camera powers on and then beeps a few times and then powers right back off.
Same as above but might also say "lens error" before shutting off.
2: Wrong size memory card --------The EXS880 can take up to a 1 gb memory card right out of the box. If you try to use a memory card larger than that you will have to see if there is a firmware upgrade available. Also Casio only recommends 3 brands of memory cards, they are Toshiba, Panasonic and Sandisc. Using any other kind can make your camera act funny.
If it is a lens error the only way to correct that is to send it into repairs. I would first make sure you are using the correct memory card. If you are then you have no choice but to send in and have it fixed.
Sep 12, 2008 | Casio Exilim EX-S880 Digital Camera
Shutdown sometimes fails - Lens retracts then immediately extends again
I am having the same problem with my camera. I have to take the batteries out to get it to shut down. I also cannot view my photos on the camera, when I try to turn it to view, it goes to shoot mode.
Aug 01, 2008 | Canon PowerShot S3 IS Digital Camera
Casio Exilim Pro EX-P600 - lens won't retract or come out
Guys - I know this sounds absolutely bizarre but I recently had this problem with my casio exilim ex p600 (with the lens sticking when powering down and not powering back up again) and it worked for me. Pulling my hair out trying anything and everything, I decided to take the SD card out, turn the camera on (at which point hopefully your lens will go back in) then turn the camera off again, Put the SD card back in and hey presto everything ok! Doesn't make any techincal sense (and I'm semi into these things) but the lens sticking\not powering up and happened to me twice now in last few months and that sequence of events is the only thing I could do to solve it! If that doesn't crack it try taking both the SD card and the battery out and doing the same. Good luck...apologies if it doesn't work for any of you guys but it did work for me :o) Let me know how you get on when\if you try it.
Apr 21, 2008 | Casio Exilim Pro EX-P600 Digital Camera
Camera turns on then auto shuts down??
when the lens comes out grab it and lightly!!! push it to one side this worked on a cannon i have
Jan 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
679 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Steven Wander
Steven Wander
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
