I plug in the unit and turn it on, and the projector projects a blue standard background (which is normal) but then there are about two dowzen vertical white lines also being projects.
  • 674 Answers
Check the connection between the unit or pc and projectors cable...
Posted on Jul 13, 2009
Using a Dell projector, is there a way to get it to project white without any inputs, versus the standard blank blue screen? It goes white when searching for inputs, but switches back within seconds when...
Since you did not provide the make and model, you will have to pull out the manual and check the settings. It may provide you with a setting change for the background color. Perhaps you can connect it to a computer, open an new blank document and project the blank image to get your white light.
Mar 28, 2015 | Dell Office Equipment & Supplies
Keystone adjustment not working
Are you projecting an image at the time? Often times you can not keystone the blue background.
Mitsubishi xd250u DLP projector Disassembly and Lens Cleaning Here is a video of the internal cleaning of this machine.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
Hello. How do I invert the image on a Toshiba TLP-2000 EDU Projector. Many thanks, Paul
Go into the setup menu.
One of them is the picture or positioning menu.
There are normally 4 options,
front projection standard / inverted.
rea projection standard / inverted.
dont move the projector whilst on or bulb is warm as bulb is very fragile at that time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 19, 2011 | Toshiba TLP-XD2000U Mobile Projector
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Image not seen on screen...only a blue background
go into the settings menu and select the computer input.
Jul 17, 2009 | Sanyo PLC XU35 Multimedia Projector
MacBook connected Hitachi CP x301 Icons do not appear
Ok what's happening is that you have it set up as an extension of your desktop, you need to mirror the displays. when your projector is plugged in and it is showing only the desktop background, open "System Preferences," click "Displays," click "Positioning" and check the box that says "Mirror Displays." This should do the trick.
Mar 28, 2009 | Hitachi CP-X301 Projector
TV took a dump
Sounds like a problem with the Hyper Board.
Dec 13, 2007 | Toshiba 65H81 65" Rear Projection...
Projector gives a red background
try video signal from video or from dvd if you get the same result you have problem inside the projector and need to be fix in workshop near you.
Nov 07, 2007 | Epson EMP 52 Multimedia Projector
Blue color
Bad contact on cables probably
Apr 03, 2017 | Sony VPL-ES2 Multimedia Projector
Computers & Internet Logo
Alun Cox
David Payne
David Payne
