Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
hi yes code 8 is a controller error try ringing a pride spare parts to c if they have reco ones .....very expensive new ones try monster scooter parts ...good luck
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
Here is the procedure for clearing ABS codes, the connector is up under the drivers side dash, it may be taped to another harness so just rip/cut the tape and pull down until you can see what your doing. Just FYI, the ABS module only holds 3 codes max in its internal memory even if there are 4 or more codes existing. Those other existing codes will not show up until you fix a concern, clear the codes, and if the light is still on all that means is that you just made room for another code to show up. As long as you only have the one code, you'll be fine. But if you had 3 codes, and you clear them, all the codes for the problem you fixed will be gone but now new codes may be there. I hope this info helps!~subyguru~Clearing Memory
After calling up a trouble code, disconnect diagnosis connector terminal 8 from diagnosis terminal.
Repeat 3 times within approx. 12 seconds; connecting and disconnecting terminal 8 and diagnosis terminal for at least 0.2 seconds each time.
NOTE: After diagnostics is completed, make sure to clear memory. Make sure only start code (11) is shown after memory is cleared.
If you have an Advance Auto Parts store where ever you are, they will read the code and tell you exactly what to code is and what it means. Any mechanic who "guesses" isn't a mechanic at all - he's a thief. Emissions leak can be any number of things, but not the gas cap!
