FixYa.com
Tags:
Ricoh IS 450SE Flatbed Scanner
Ricoh is 45se scanner squeaking loudly
posted by e-techie on Nov 15, 2007
Just wanted to see if you could give me some insight on this. The squeaking usually occurs after say 50 pages are sent to it. Then from there it will start out at a low pitch but it seems it get louder the more pages come out. Do you haver any suggestions on what may need to be cleaned or may be loose within the scanner? Yuor help would be greatly appreciated.
Erik
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 16, 2007
Helpful (85)
MUKHTAR
Rank:Wiz Wiz
Rating: 77%, 435 votes
see if you are able to open the cover if you success then use any lubricant oil and apply on scanner head steel rod .
bye
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Scanners problems?
Scanners
scanjet 4050
can not install software from... Answer This...
Scanners
driver for umax scanner 4500
i can't find driver for umax... Answer This...
Scanners
help
do you have scanner codes Answer This...
Scanners
canon Scanner canon F914900
i need driver of canon Scanner... Answer This...
Scanners
PILOTE POUR SCANNER CANON
Bonjour Je souhaite recevoir le... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
