I have a Gaggenau cm 210, and the water comes out through the bottom, not the front any longer. Would a new brewing unit fix this? Seems to grind allright and it seems that hot water dies reach the brewing unit, but only to end up in the tray. The water - a lot, that comes out underneath is cold.. Kindly help. Br Tor
The water in unit is fed via a hose to the heating element. If the hose is broken or disconnected the water never reaches the element and spills out the bottom nice and cold.
If you remove the bottom panel the problem will be instantly obvious.
OR put water in unit and see where it comes out of!!!!!!!!!
